  1. I have a weird question; i got a new computer an AMD athlonXP 1600+ with 256DDR ram and Radeon 8500 when i convert movies to SVCD it seems that it is taking a while to encode the movies about 15 hours to enode a svcd i am only using
    Noise Reduction filter
    CBR 1150bits avg
    motion percision high quality
    4:3 aspect ratio NTSC
    under Quantize matrix i have checked
    Output YUV data as basic YCbCr
    Use Floating Point DCT
    No motion search for still picture
    i asked a friend of mine that has the same porcessor and he can do a svcd just under 9 hours but i'm taking 15 hours is this normal or is something wrong with my computer?
  2. and i am using TMPGEnc
    PS
    is there a guide out there that explains on how to use CCE 2.5SP?
    Aug 2001
    Hull
    Just use DVD2SVCD ( http://dvd2svcd.doom9.net/ ), its very easy to use & it took me around 10 hours with a 1 Ghz Athlon with 512 sdram, & that was with cce 2.50
