I have a Toshiba SD-kp19sn portable DVD player and I usually used the power supply for watching DVD and when ever I turn the power off I noticed that the charging indicator would start blinking but after a while it will disappear. Lately I noticed that the indicator hasn't stop blinking for more than 2 days and according to the manual the battery should be fully charge within 3.5 hours. Can anyone tell me what's going on? Is the battery about to die even though I haven't used it?
I am going to guess that the battery is not able to charge all the way anymore, or the detector is failing.
If you had the charger plugged in to watch the videos, you were charging the battery.
Laptops suffer a similar fate. I only use mine with the charger plugged in and the battery's shot. It would probably have lasted longer being discharged periodically.
But either way, batteries wear out. Some quicker, some slower. I'd start shopping around for a replacement battery. You may not have to use the ones from Toshiba, which may be a bit expensive. But be careful out there! There are some really crappy batteries available at some internet discount sites. Check around for feedback before you order.
I'm not familiar with that particular player, but with some players battery replacement is a real chore. I'd recommend doing some research first. Do a internet search for the player + battery and one for the battery, using specific brand and model of the battery.
Hulu to start charging for subscription based service in 2010
By freebird73717 in forum Newbie / General discussionsReplies: 11Last Post: 24th Oct 2009, 14:15 -
.mov to flv conversion does not show video progress indicator
By Phranque in forum ffmpegX general discussionReplies: 1Last Post: 20th Sep 2009, 05:58 -
Canopus ADVC55 red light status indicator
By bobmccredie in forum Capturing and VCRReplies: 0Last Post: 13th Sep 2008, 01:10 -
Pause/Stop mode won't hold with Coby DVD-755
By JohnnyBob in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Sep 2007, 09:04 -
Charging my camcorder on a fly-in fishing trip?
By oldtwohairs in forum Newbie / General discussionsReplies: 3Last Post: 30th Jul 2007, 17:53
