I bought an HD PVR a few days ago so that I could record videos at a much higher quality. I have successfully been able to hook it up to my Xbox 360 and PS2 without any problems whatsoever (except for the setup beforehand which took over 3 hours, but that's an entirely different story). However, when connected to my PS3, the quality is a bit...well...the video link below will show you.
http://www.youtube.com/watch?v=vNt2vcntpM4
This was a similar problem a few months ago when I was using a Dazzle to capture footage, only the quality on that was much, much worse. There seems to be a kind of flickering on the screen and slight overshadow, as it were.
Any assistance would be appreciated. I am using a 32 bit Sony VAIO top of the range laptop. I'm using Total Media Extreme to capture the footage.
	try shielded cables, if not use shorter cables, I'd say 6 feet or shorter. also are you using component or composite video out?
	I'm using Component cables. In fact, every cable I have set up right now is new. Since the PS3 had the same problem with my Dazzle a few months back when using different cables to the ones I have now, I'm beginning to think there's a problem with the PS3 itself, or possibly a driver. I'm not entirely sure.
	It seems to be cable problems.
 I use AVERTV to recording my PS3 videos and looks very good.
 Watching Componente record video:
 Change the cables (Sony PS3 component).
	I bought the official Sony component cables, which cost me £20 and took a while to get here. The difference is startling. All issues have been resolved. Thanks for your help, guys.
  I have a few questions regarding capturing with AVerTV HD PVR and a PS3.By phenom97 in forum Capturing and VCRReplies: 2Last Post: 22nd Sep 2010, 09:02
  Hauppauge HD PVR or HAVA Platinum HD to record PS3 GamesBy leandrokoiti in forum Capturing and VCRReplies: 9Last Post: 20th Feb 2010, 09:37
  HD Streaming with GB-PVR, WinTV-HVR-1250, TVersity, and PS3By ttfitz in forum Media Center PC / MediaCentersReplies: 2Last Post: 29th Sep 2008, 22:43
  PS3 Interlace ProblemBy Anakin in forum Blu-ray RippingReplies: 5Last Post: 7th Sep 2008, 18:39
  WinTV PVR 150 problem and Geforce 7600 GS problemBy deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
