I have many vfr mp4 videos and I want to convert them cbr avi. For a few days, I searched Internet and I didn't find any quality information. VFR wmv videos convertable with Virtualdub with some codes. But my mp4 videos have AAC audio and VirtualDub can't convert this audio type, so a/v synchronization lost. Megui and some other rip tools nearly always perform synchronization lost for variable videos. So I think vfr videos must convert with any converter audio and video together. VirtualDub can do this but Megui and other tools can't do that. And last I said, VirtualDub can't convert AAC audio.
So I need program and codes for vfr mp4 to cbr avi.
I don't know super advanced video coding. Please give me exact solution with half advanced-half simple details.
I have K-lite Mega Codec Pack last version
Windows XP SP3
Core2Duo 2.93 GHz
3 GB RAM
VirtualDub
Megui
Transcoder
Thanks.
VFR mp4 sample with media info:
Video
Format : AVC
Format profile : Baseline@L1.3
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 20mn 26s
Bit rate mode : Variable
Bit rate : 2 307 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 29.970 fps
Minimum frame rate : 29.960 fps
Maximum frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.251
Stream size : 337 MiB (95%)
Encoded date : UTC 2008-10-17 09:43:41
Tagged date : UTC 2008-10-16 09:44:25
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 20mn 26s
Bit rate : 128 Kbps
Maximum bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 18.7 MiB (5%)
Encoded date : UTC 2008-10-17 09:44:13
Results 1 to 1 of 1
How can I encode using VFR, mp4 output?
By The Scenes in forum Newbie / General discussionsReplies: 4Last Post: 18th Apr 2011, 19:34 -
MP4 to avi without conversion?
By forcedv in forum Video ConversionReplies: 1Last Post: 14th May 2010, 20:02 -
Conversion avi - MP4
By condorsoaring in forum Video ConversionReplies: 5Last Post: 7th Oct 2009, 05:14 -
avi to mp4 conversion speed
By killcorvus in forum ffmpegX general discussionReplies: 1Last Post: 15th Jan 2008, 17:41 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 2nd Aug 2007, 00:41
