I have a short clip with background music that i imported into authoring works 4. I have enabled "motion menu with audio" in global menu settings. Why is the menu clip silent during simulation playback?? Both clip audio and background music is silent. The tracks play fine. Also, i output to blu ray and no audio either when the menu played.
thanks for any help.
Could be the audio is in a format not supported by AW4. Is there a setting to use background music for menu audio?
Yes but i bypassed that since my motion menu contained the background music i wanted.
Did you check in the BGM editor in the menu/page editor to see if the audio from the video file could be used?If not then you have to extract it and add it in the BGM editor section.
Does Tmpgenc Authoring works 4 support motion background menus?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 10th Mar 2011, 03:35 -
TmpGenc Authoring Works 4 - Motion Menu Question
By blazin-j in forum Authoring (Blu-ray)Replies: 3Last Post: 18th Oct 2010, 11:00 -
Menu question re: TMPGEnc Authoring works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 9th Jun 2010, 08:32 -
TMPGEnc Authoring Works 4 - Menu help
By NotSoEasy in forum Authoring (DVD)Replies: 9Last Post: 1st Mar 2010, 03:24 -
TMPGEnc Authoring Works 4 Single Menu
By Sakuya in forum Authoring (DVD)Replies: 3Last Post: 22nd Dec 2009, 03:04
