Hi
First time posting and new to this. I am trying to import an avi. file into Adobe Premiere but it continues to say importing but never does anything. I have imported an mpeg with no problem.
Any help would be appreciated
Results 1 to 9 of 9
Fitch.j
Thanks for the reply, I am using Adobe Premiere Pro and here is the info you requested from the Medi info download.
General
Complete name : K:\JessicaVideo\FastCrawl.AVI
Format : AVI
File size : 5.01 MiB
Duration : 9s 810ms
Overall bit rate : 4 283 Kbps
Recorded date : 2009-05-10
Writing library : AMBA
ICRT : 17:28:14
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=15
Codec ID : H264
Duration : 9s 810ms
Bit rate mode : Variable
Bit rate : 4 188 Kbps
Maximum bit rate : 4 001 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.152
Stream size : 4.90 MiB (98%)
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : FF
Duration : 4s 847ms
Bit rate : 128 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 48.0 KHz
Stream size : 75.7 KiB (1%)
Alignment : Split accross interleaves
Interleave, duration : 22 ms (0.65 video frame) -
He means what version of premiere (e.g. Premiere Pro CS5 , Premiere Pro 2 etc..)
If you install ffdshow and enable h.264/avc in the ffdshow vfw configuration (yellow icon) it should import the video
Another approach you could try is re-wrap the video into another container e.g. yamb to re-wrap into mp4 , or tsmuxer to re-wrap into .m2ts -
no , ffdshow in this context is just a decoder
the other option listed above just "repackages" the contents into another container (think of putting the audio & video into another box , because premiere doesn't "expect" that type of video in an AVI container or "box" , it expects that type of video & audio in another type of container)
If all those fail, then you could convert it to a compatible format, but you still haven't answered the question which version of premiere ? -
Sorry guys, I'm also having issues with my desktop which I go online with. My version of Adobe Premiere is 7.0. I'm going to try some of the suggestions you have given today and see if I can work some of the magic you guys have shared. NOt sure what I'm doing but will take a stab at it. Thanks!
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 21:39 -
Problems Capturing/Importing Video into Adobe Premiere Pro
By Texas in forum EditingReplies: 3Last Post: 15th Apr 2010, 02:56 -
(update)Importing .mkv to Adobe Premiere CS4
By yodnnee in forum EditingReplies: 1Last Post: 23rd Jan 2010, 09:58 -
Trouble importing Quicktime movie into Premiere Elements 3.0
By srudder in forum Newbie / General discussionsReplies: 3Last Post: 8th Feb 2008, 11:53 -
Help With Premiere Pro 2 (importing Screen Captured Avi File)
By paulinnorway in forum EditingReplies: 2Last Post: 15th Oct 2007, 11:19
