Does anyone have an idea how to hook up this particular dvd player to the tv? All I want is the dvd
player to work
the back of the player has the following hookups:
tv audio in
vcr audio in
aux
line out
(these are all white and red)
video out (yellow)
y (green)
Pb (blue)
Pr ((red)
(these are under "component video output)
my other equipment has 3 colors. yellow, red and white. Can this even be hooked up to the tv?
thank you
I believe the particular model you are describing is a combined DVD player (5 discs) and surround sound system. What sort of TV do you have? The Panasonic unit should also have an HDMI interface for HDTVs, but you can certainly use the component outputs on an HD set. However, if you have an old, standard TV set (which is how it appears by your post), you will need to run an RCA line from the DVD player's yellow video output to the yellow video input on the TV. Likewise, red and white audio cables go from DVD line outputs to the corresponding inputs on the TV. Use RCA cables.
Do you not have surround sound speakers for the Panasonic unit? Seems like a huge waste, if not. Yours is not just a run-of-the-mill DVD player.
If you do not have the owner's manual, try downloading a .pdf version from the Panasonic website. -
Thank you for your reply. Yes, it is a 5 disc surround sound unit, but I don;t have the room
to hookup everything
I;m currently using a RCA tv (1996) and it only has the three color inputs i;ve mentioned. (red,white,yellow)
as is my cable box. No single yellow connection
The dvd unit looks like it was mauufactured in 2000, with a copyright of 1996
My previous dvd player worked because it had the appropriate 3 color connection
Does it seem to you that the unit is not compatable due to the 2 wire connections?
Maybe the unit is too old?
thanks again
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
XBOX 360 HD-DVD sound popping when HD-DVD starts only with HDMI hookup
By vatkat234 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Jan 2009, 21:03 -
record to standalone dvd from my dvr - hookup
By Noek in forum DVD & Blu-ray RecordersReplies: 7Last Post: 25th May 2008, 10:41 -
Panasonic S53 DVD player
By EvilWaffles in forum Newbie / General discussionsReplies: 2Last Post: 1st Mar 2008, 11:30
