Hi,
Well i have media file whether its MP3 Movie anything.
For MP3 i use Mp3Tag and edit the tags.
Sad part is when i putted this file under the MediaInfo software.
It showed more tags of this file.
Well I need all global and not niche information of how can i edit the tags of movies and MP3 etc
An example of an video information. An movie
General
Complete name : C:\Users\Desktop\Away We Go 2009.avi
Format : AVI
File size : 316 MiB
Duration : 1h 37mn
Overall bit rate : 452 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2542/release)
Writing library : VirtualDub build 32817/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 37mn
Bit rate : 307 Kbps
Width : 640 pixels
Height : 272 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.074
Stream size : 215 MiB (68%)
Writing library : XviD 1.0.2 (UTC 2004-08-29)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 37mn
Bit rate mode : Variable
Bit rate : 132 Kbps
Minimum bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 92.4 MiB (29%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 139 ms
Writing library : LAME3.98r
Encoding settings : -m j -V 4 -q 0 -lowpass 17.5 --vbr-new -b 128
Respected: jagabo, guns1inger and redwudz
I mean how to edit information of Media file fully.
Respected: jagabo, guns1inger and redwudz -
Probably the most comprehensive tag editor for avi files is ABCavi tag editor. If that doesn't change enough fields for you then you will have to write your own application to do it.
That said, most fo the fields should not need to be changed, and are derived from the properties of the video or the encoder.
MP3 tag editors have been around for years. I don't use any, so I can't recommend anything beyond googling for one.Read my blog here.
Got the answer from gunslinger.
Which is best MP3 Tag Editor?Respected: jagabo, guns1inger and redwudz
Editing Media Information in Video file
By ConverterCrazy in forum EditingReplies: 0Last Post: 19th Mar 2012, 02:58 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
Media information program
By rocks911 in forum Newbie / General discussionsReplies: 8Last Post: 12th Aug 2011, 12:33 -
Video Quality for full screen on Media Player Classic?
By mimioreo in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2010, 18:33 -
*SOLVED* Media problem or workflow problem? (Media problem)
By nosleep in forum Authoring (DVD)Replies: 7Last Post: 2nd Jan 2008, 20:35
