Hi All, I am a Newbie my computer is my Hobby! I am still learning" but I take a long time to absorb stuff especially this.So here goes. I will ask 3 questions as they are a bit different.
1) Can I Download a Movie ‘AVI etc’ save it to my ‘Hard Drive’; then encode it with MediaCoder with whatever Coding will work?
Then Burn it to a Video-CD-RW 12/700mb/ (I do not have a DVD Burner)! Then Play them back on my digital DVD-Recorder – Player and DigitalTV? If so What encoding do I use and can you explain in detail please?
I have all the Spec’s of what my Digital DVD-Recorder/Player can play. I have already tried with a “movie” that was AVI but the Player say’s “No Disc” yet when you Read the DVD Players Spec in the 'Manual' It states ‘AVI’ ‘Divx’ The Playable codec’s are listed as:
DIV3-MP4-Mp2-Mp3 and DX503 the Audio listed is AC3 m-PCM-MP2- MP3-WMA CD Format - ISO 9660 JOLIET (See the Attachment) Remembering I do not have a DVD Burner.
2) Can I also download and save Video Streams of TV repeat Docos and program's has and put them on a Video-CD-RW and Play them on the DVD-Recorder/Player. DTV
Hoping you can help Cheers Dasha
3) Can I download non Protected DVD Movie to my Hard Drive and do that same as above.
My Computer is for “Home Use” and my hobby! It Is: a 2003 - Dell Desk Top with LCD 20" Screen, Intel Pentium 4 CPU, 2.80 Gig (75 % ) Un - used + 512 Meg Ram with Intel 82845G/GL/GE/PE/GV Graphics Controller’ and Running MS Windows Pro XP P3 & MS Office 2007 (Non Commercial)! In addition, MS Wireless Keyboard and Mouse.
You can just buy a DVD burner for $20 and have a much higher quality of 4.3GB per disc versus 700MB on your CD
Then you can learn to make DVD's properly
or you can just save the videos as you find them for playback from your computer's hard drive -
Your player might only play avi's from DVDR disks instead of CD's. Or it might only play avi's from CD-R's rather than CD-RW's. Or your avi's might not be compatible with your player. You need to check your manual to see what media your player will play avi's from.
You also need to check you avi files to see what they contain. You can use MediaInfo for this.
Check this sticky too -
https://forum.videohelp.com/threads/295067-Common-DivX-DVD-Players-AVI-Playback-problems! -
Thanks KBeee and zoobie I have downoaded AVIRecomp thanks KBeee! I will also take a long hard look at buying a DVD Burner zoobee. Both are good solution's a lot easier and less confusing for me. I am so glad I found this site. Cheers to you both. Talk again soon Dasha
X264cfw encoded file does not play in Adobe Flash Player 10.
By RussellB in forum Video ConversionReplies: 1Last Post: 14th Nov 2008, 22:49 -
Would this DVD player play AVI files burnt onto a blank DVD/CD?
By jane2 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th Apr 2008, 20:38 -
Please help me with getting my burnt dvd's to play in dvd player!
By celesta525 in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2008, 20:47 -
unable to play authored & burnt dvd on standalone player
By rancid in forum Authoring (DVD)Replies: 15Last Post: 10th Jan 2008, 21:24 -
Burnt several AVI's in Vista but won't play on Divx player... help
By mdavenport in forum DVD RippingReplies: 3Last Post: 29th Aug 2007, 14:51
