Hello,
I Got my Intensity Shuttle yesterday but I still does not work at all(followed their steps to update USB 3.0)
Steps I have tried:
1.Latest NEC 3.0 USB firmware + Driver
2.Latest Intensity Shuttle driver from website.
Whenever I plug it into the USB 3.0 port it says: "Unable to properly install your USB 3.0 device"
under the device manager it sees as: "Uknown Device" your driver may not have been installed
Also tried pluggin into the USB 2.0 port to see what would happen and sure enough it recognizes as a "Intensity Shuttle"
But the product doesn't work of the USB 2.0 port .
Also tried with disable UAC and windows compatabiliy option, run as Admin... as well.
Obviously something's not right, something with the intensity shuttle driver and usb 3.0 driver/firmware not liking each other.
Anyone got any ideas?
Systems Specs: Win7 pro 64 bit
Rampage Extreme III with NEC Onboard USB 3.0 Controller
Corei7 930
WD Black Caviar Raid 0
My problem is the same! if you can contact us via skype ... my contact is: hard--core
This may be a long-shot but where exactly did you get your firmware/driver update(s)? The reason I ask is because when I went to the official site the firmware/driver update links where both for the driver update and not the firmware. I was forced to google the firmware update to get the correct file. Anyhoo, good luck.
Got it figure out! it was a simple mistake I was overlooking... I was using WRONG Driver set.
The driver on the disk was the wrong for starters.(for Intensity PCI EXPRESS!)
I downloaded the wrong set from the website as well which was a newer version of these WRONG drivers..(for Intensity PCI EXPRESS!)
Hardxeno easy fix for us download the correct USB 3.0 drivers version 7.7.1
on the software section on the Blackmagic Design part of the website go to:
USB 3.0 Editing, Design and Paint 7.7.1 DRIVERS
The USB 3.0 Desktop Video 7.7.1 drivers include support for Intensity Shuttle and UltraStudio Pro. Further information about the latest drivers is available in the individual Readme files for Windows.
Hope this help if anyone is having problems, as it turns out wrong drivers are the disk which is misleading.
If you downloaded the Software and the firmware link was for the same software, there's a file in both 32 and 64 folders called FWupdater32.bat and FWUpdater64.bat, depending if your running 32 bit or 64 bit. Run ththe appropriate one and it will update the firmware. Hope this helps, Danny Hays
Intensity Shuttle problems
By Canesin in forum Capturing and VCRReplies: 1Last Post: 6th Jan 2012, 17:09 -
Black Magic Intensity Shuttle or Intensity Pro?
By perasbro in forum Capturing and VCRReplies: 3Last Post: 12th Oct 2011, 17:56 -
Intensity Shuttle help please..
By Norwalk2006 in forum Capturing and VCRReplies: 3Last Post: 13th Sep 2011, 21:52 -
Problems with detecting my Blackmagic Intensity Shuttle
By Arceopteryx in forum Capturing and VCRReplies: 0Last Post: 22nd Jan 2011, 03:40
