Ok so I have got the Sony Blu Ray BDp-S370 with remote control RMT-B107P and it gives me the codes so I can control my TV but not how to program the remote to do so.
So guys how do I program the remote so that it change the volume on the TV the television is a Samsung and the code is 71
Thanks in advance
Kriss![]()
- Hold down the TV I/O (small green button) on the remote.
- While holding that down, enter you TV's code (found at the back of the instruction manual)
- Release the green button.
Glad I could help
Sorry it took so long to reply. Only found your post by luck while searching for something else on google
Hi Bigglesinc, Do you know how to open up the BDP 370 to all regions using the RMT-B107P remote?
ken -
Hi Ken,
I'm sorry but I don't think you can do it using that remote.
You can set the player to multi-region for DVD's by using the method at http://www.avforums.com/forums/blu-ray-dvd-player-multiregion-hacks/1178732-diy-sony-b...-manually.html
I believe the only way to get multi-region on the blu-ray side is via hardware alterations.Last edited by bigglesinc; 15th Mar 2011 at 03:17.
Sony BDP S370 DVD region hack - which remote to use!?
By bubbafurn in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Jun 2017, 05:49 -
Sony BDP-S370...
By Paddy Coleman in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th May 2017, 11:41 -
Sony BDP-S370: .mkv Playback Problems
By MWisBest in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jan 2017, 00:54 -
Sony BDP-s370 hack problem..
By manicjon in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2011, 08:41 -
Can't play DVD+R on Sony BDP-S370
By sconepanman in forum MacReplies: 8Last Post: 2nd Dec 2010, 14:42
