Hi,
I'm trying to merge together raw WMA Pro audio streams with some WMV video streams with mkvmerge. The program automatically detects the format of the WMV stream ok, but I'm not sure if mkvmerge even supports it.
What is the best way to get mkvmerge to accept it?
Ideally I'd like the final mkv to have the same audio in WMA Pro codec, but encoding is ok if its the only way to get it to work.
Thanks.
Apologies for my ignorance, but I am not aware of any application capable of muxing
"containerless" WMA into ASF, not to mention into Matroska...
BUT, if by "raw" WMA streams, you mean simply "proper .WMA files",
the older versions of Gabest's MatroskaMuxer can create intermediate .MKAs which
will/should be happily accepted by MKVmerge.
Is it possible to take VC1 & convert DTS-HD to WMA Pro 5.1 and mux to WMV?
By bobthegoat2001 in forum Authoring (Blu-ray)Replies: 5Last Post: 16th Dec 2011, 11:12 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 12:25 -
Help with WMV9 (MP) and WMA pro conversion
By CDIZX3 in forum Video ConversionReplies: 4Last Post: 10th Feb 2010, 02:52 -
Need to convert raw .h264 stream to edit in Vegas Pro 9
By cintec in forum EditingReplies: 18Last Post: 9th Aug 2009, 13:44 -
decoding wma pro possible?
By yedio in forum AudioReplies: 2Last Post: 27th May 2007, 16:19
