I'm very new to all this and don't know much about codec's, containers all all this stuff, so I need a lot of help!
A friend introduced me to Nero Recode about 6 years ago (I think it was version 6) and I have been very happy, using it to convert all my, about 1500, DVD's to AVCHD (2-pass, 3Mbps). Before my current setup, I used my PC to view the movies, but now I have a 50" Pioneer Plasma Kuro and it can play the movies directly from a USB-stick (will be connected via network soon)!
Time change and all the new movies I buy is on BluRay, so now I have a problem, because Nero Recode can't convert them! - What do I do to get all my BluRay movies converted to one ACVHD file and what bit-rate should I use to get a loosless or almost lossless encoding (I prefer to be able to encode all movies with the same bit-rate)?
Any help and/or input is wanted!
welcome to the forum!
too bad about nero, most people here won't use it, as it's garbage.
you might try multiAVCHD it's free.--
forgot the other one - AVCHDCoder might also suite you, also free.
Also RipBot and BDRB, both free; they can output to AVCHD or MKV files.
[EDIT] multiAVCHD is great, but maybe not the easiest program for a novice.Pull! Bang! Darn!
AVCHD to BluRay question (again)
By pijetro in forum Authoring (Blu-ray)Replies: 0Last Post: 8th Jan 2012, 14:04 -
CS4 project to BluRay or AVCHD DVD
By thhedk in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Aug 2011, 13:34 -
One click BluRay to AVCHD pay software?
By Killingtime01 in forum Authoring (Blu-ray)Replies: 2Last Post: 15th Mar 2011, 06:51 -
convert mpeg4 back to avchd or bluray
By davebarnes2009 in forum Video ConversionReplies: 1Last Post: 28th Jun 2009, 08:21 -
Bluray to AVCHD questions...
By alcOre in forum Blu-ray RippingReplies: 2Last Post: 12th Dec 2008, 13:36
