Results 1 to 10 of 10
  1. hello I bought a shuttle intensity but I can not install it ... when i connect the intensity shuttle to the PC via USB 3.0 tells me that the drivers are missing and can not find ... help me please ...
    Oct 2005
    666th portal
    do you have one of these motherboards?
    • ASUS P6X58D-Premium
    • ASUS P6X58D-E
    • Gigabyte GA-X58A-UD7
    • Gigabyte GA-X58A-UD5
  3. i have a
    INTEL DP55WG
    Oct 2005
    666th portal
    check to see if it uses the nec usb 3 chip.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    back up a minute. are you trying to use onboard usb 3 or an add-in usb 3 card?
  6. i have a expansion card NEC CHIP USB 3.0
    Oct 2005
    666th portal
    make sure your card is in one of the allowed type of pci slot. and did you follow this guide?
    http://www.blackmagic-design.com/downloads/software_readme/ReadMe%20before%20you%20install.pdf
  8. The version of NEC and firmware is right
    PS; my OS: win 7 pro
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    you ran the installer software off the cd and did any updates? used the usb 3 cable?
    the only thing i can think of to try would be to re-run the installer, but right click on it from the cd and choose run as administrator. for win7 it sometimes helps.
    it may be time to contact intensity support. not much more anyone else can do for you.
  10. Mine does this also but still seems to function. I simply cancel the pop-up and continue with capturing. Good luck.
