Hi,
I recorded with my Canon HV20 a video which I want to slow down. So I set the camera to interlaced mode, and I use a script with MVTools:Source(...myvideo.d2v)The resulted clip as you can see in this video (I put it on Mediafire too) is shaking in strange way. I tried to stabilize it with Deshaker but without succes, because different parts of the image moves in different directions. It could be a problem of mpeg2 encoding during the capture because of the constant motion of camera. What do you think? The uploaded video have two parts, in the first I only deinterlaced and resized the original, in the second part I used Bob, Slow motion script and resizing to 720p.
Yadif(mode=1,order=1)
smoothfps(75)
assumefps(25)
function smoothfps(clip source, float fps) {
fp=fps*75
backward_vec = source.MVAnalyse(isb = true, truemotion=true, pel=2, idx=1)
# we use explicit idx for more fast processing
forward_vec = source.MVAnalyse(isb = false, truemotion=true, pel=2, idx=1)
cropped = source.crop(4,4,-4,-4) # by half of block size 8
backward_vec2 = cropped.MVAnalyse(isb = true, truemotion=true, pel=2, idx=2)
forward_vec2 = cropped.MVAnalyse(isb = false, truemotion=true, pel=2, idx=2)
return source.MVFlowFps2(backward_vec,forward_vec,backwar d_vec2,forward_vec2,num=int(fp),den=75, idx=1,idx2=2)
HV20 uses a CMOS chip which has a rolling shutter - different parts of a frame are exposed at different segments of time.
This makes it prone to jello shakes from vibrations, skewing on pans, and flash banding
CCD sensors are immune to this
Search for "rolling shutter" , "CMOS" , and "CCD" on google
Deshaker has partial rolling shutter correction (it can help reduce the skew) , but cannot help the "jello"
example of what skew looks like on CMOS camera
http://www.vimeo.com/6894404
example of CCD vs CMOS when vibrations are present
http://www.youtube.com/watch?v=UEaDrS-yzIE -
Thank you very much poisondeathray!
Now I understand the source of problem. I have found on this page (post#24) that in Deshaker we have to set the Rolling Shutter amount to ~40% for HV20. This way the results looks better, but no perfect because of "jello"as You warned. There are no other way to improve the correction?
No other way to improve it after it's been recorded. You can improve the skew by various methods, but not the "jello" very much
There is an expensive plugin for After Effects and Nuke, called RollingShutter by The Foundry, and it improves the jello a little bit (but still not perfect)
Jello is almost impossible to fix, because there are different motion vectors all moving at different velocities with different acceleration/deceleration
You have to pay more attention to shooting technique next time
What is AVCHD recording, how will it effect me?
By seven1970 in forum Video Streaming DownloadingReplies: 14Last Post: 19th Nov 2014, 07:51 -
How to remove shaking camera effect
By jairovital in forum RestorationReplies: 20Last Post: 17th Apr 2012, 14:29 -
Video techniques - shaking zoom in and zoom out effect?
By Mylo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Oct 2011, 11:08 -
Event crop in Sony Vegas creates a strange effect
By Srivas in forum EditingReplies: 5Last Post: 23rd Mar 2008, 22:23 -
Hard-disk-videocamera instead of miniDV-videocamera
By Mållgan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Jan 2008, 11:58
