I've done DVD backups on both my desktop and laptop systems. And, backups on the desktop work just fine. But my laptop has recently begun to act strangely. When I put my original DVDs into the drive, I get "no disc" messages with DVDdecrypter, DVDshrink, and DVDfab. And most of my original DVDs are of "old" movies (example, "The Big Country"). However, when I put in the backup copies I've already made, they read just fine. It's almost as if some utility I can't recognize is singling out all of my store-bought DVDs and giving "no disc" warnings.
Anybody have any clue as to what's going on here? I could understand it if it "couldn't copy" a particular disc - but it just gives me the "no disc" message all the time ... old DVDs or new.
P.S. FWIW, the DVD burner still burns DVDs OK. And it still reads all my backup copies. Just not the originals. Weird.
Regards,
J. Alec West
It does sound like the burner (or more precisely, the reader part of the burner) is starting to fail.
Pressed discs are different to burned, but likely it will get progressively worse and you won't be able to read burnt ones soon.
That was my experience with an aging burner -- I was clicking "load" dozens of times in Imgburn to get it to recognise a disc towards the end.
But try a cleaning disc (with the little brush on it) if you have one, may help, can't hurt. -
Although your burner may be failing, I did have one commercial DVD that would not play on my Panasonic es40v. I got it from a bargain bin at walmart and it was twice as thick as a normal DVD, I made a copy of it and the copy played fine. I guess my unit didn't like that particular DVD.
Agree it's probably a failing drive. I had a burner that did the same thing. Quit reading pressed discs but read burnt discs just fine. Eventually it quit reading those burnt ones as well and I had to replace it.
Donadagohvi (Cherokee for "Until we meet again") -
Thanks to all for the advice. The drive has been around the block more than once (grin) ... so it's probably just time to replace it. New drives are a lot cheaper than they were a couple of years ago so I'll probably just buy two of them and keep a "spare" in a closet for the future.
Again, thanks.
Regards,
J. Alec West
CDs, DVDs, & BDs ARE all the same thickness, which is exactly 1.2mm (give or take a few microns). This thickness is a standard that is set in stone. I don't think even those who made that which ended in the bargain bin at walmart will ever allow themselves to be caught dead with a 2.4mm thick DVD. You're an Amtrak mooner, right? Go get a caliper and see.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
CD tends to be thinner, due to single platter design.
Not a sandwich like the other two.Want my help? Ask here! (not via PM!)
ImgBurn "options" problem/directly cloning DL DVD to a blank disc
By gastrof in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2012, 20:40 -
"can't read disc, check disc" problem
By ttheb1 in forum Authoring (Blu-ray)Replies: 1Last Post: 13th Jun 2010, 06:34 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08 -
Daewoo DVD P480 "no disc" problem
By zodiax in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Jan 2008, 07:28 -
Sony RDR-HX525 DVD recorder- Problem with disc "Zapping"
By shytalker in forum Newbie / General discussionsReplies: 0Last Post: 30th Jun 2007, 04:56
