Hi People
Here is a guide on how to make XSVCD
If someone of youre rich Please send me money!
I have another guide to which i have tested with seg2000 DVD player!
How to make XSVCD
A Xsvcd can have followin resulotion 720x576 or 480x576 (PAL)
Its ver yeasy to make XSVCD.
You need just LSX ENCODER
Then you open the source in LSX MPEg ENcoder
Then you Choose the resulotion 720x576 or 480x576(Pal)
Then you Choose the bitrate, the only thing you have to do now is to check how much bitrate your dvd supports
Dont Check for Any stream format
How to burn the XSVCD
Now u have to just start Nero
And then you select Super Video Cd
Then you uncheck the Standard Supervideo thing
THen you select the encoded mpeg2 file
Thats all people
Use only XSVCD if the source is DVD or High Quality Div
With high quality divx i mean min 1400kbs bitrate
How to make your own guide
By Baldrick in forum User guidesReplies: 5Last Post: 25th Mar 2020, 16:10 -
Guide How to make a dvd with selectable subtitles on Mac OSX with ffmpegX
By ulmis in forum ffmpegX general discussionReplies: 29Last Post: 24th Nov 2010, 12:54 -
AVIDemux : HOW TO MAKE VIDEO CLIP GUIDE
By Bonie81 in forum User guidesReplies: 14Last Post: 26th Aug 2010, 01:41 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 15:05 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 11:34
