  1. Well, I have yet another small question about avisynth, except this one is much simpler in my opinion.
    Basically I am wanting to add a soundclip on top of any audio that might already exist at a specified time interval.
    Is there some kind of function or plugin that would allow me to do this easily? If there is not one I'm guessing I will have to add some silence before the audio clip and then mix the two audio files together?
    Thank You,
    Adam
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    http://avisynth.org/mediawiki/MixAudio
    But yes, only mixes the entire track, no offset.
    Use Tone() to generate some silence:
    http://avisynth.org/mediawiki/Tone
    But you need a video track to use most functions, so maybe BlankClip would be simpler
    #Overlay Comments.mp3 (length 1000 frames) starting at 2000 frames offset.
    AviSource ("Original.avi")
    voiceover=BlankClip(last,2000) ++BlankClip(last, 1000).AudioDub(DirectShowSource("comments.mp3")))
    MixAudio(last,voiceover)
    Need to calculate the durations in frames; there are ways to do that in Avisynth if you need to do it often.
  3. Yes, but that only allows you to specify volumes, not actual time positions. That was what I was going to use if such a function doesn't exist.
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I expanded my answer, see revised post.
  5. Okay, that was quite informative. Thank you for your assistance.
    Jul 2009
    Spain
    The voiceover clip doesn't need a video track, so you can just use:
    voiceover=DirectShowSource("comments.mp3")
    Trim(0, 1999)++Trim(2000, 2999).MixAudio(voiceover)++Trim(3000, 0)
    A more serious problem with your version is that the sound track outside the voiceover section would be reduced in volume by 50% (since mixed with silence).
  7. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Right. Your method is better.*
    Sorry you have to keep correcting me.
    Actually, the only times I really use Avisynth mixing is to downmix to stereo or mono.
    For overlaying commentary tracks I use Audacity; so I was thinking like that, as mixing silence + track in Audacity causes no change in volume.
    Perhaps this method, which I actually use, might be helpful:
    For some TV shows I found a full-length podcast commentary online; if I cue it right it applies to what you see on screen. So I export the audio from the video, and then in Audacity use the "Compressor" filter to knock the volume down to -29 dB (works for me); then add the commentary track; mix them to make an alternate audio track. The original audio is still audible in the background but the commentary is clear.
    * Though one possible problem with dubbing a bare mp3 is that if it's VBR, it quickly gets out of sync -- Avisynth doesn't know how long it really is. If CBR then it's okay. I use CBR MP3 for patching audio (replacing advertising VO with music on TV shows, for instance).
  8. Thank You both. I will probably just use audacity for a little bit, but I may tweak around with the suggested avisynth code, and see where it brings me.
