Hello guys. I know i'm at the right place to ask this and i know you guys will come up with a nice solution
here is the issue.
I'm new to captuing. like this will be my first time ever. and i am seeking help.
I've xbox 360 and Ps3 both connected to my 24" BenQ Full HD Screen via HDMI using the 10$ HDMI switch which is awesome.
now i'm want to be able to play and Capture at the same time and all Capture cards that are within range (40$) are using component or composite video and i can't use the Component cable trick as this way i will not be able to play at the same time i record the games i play.
My range is narrow i know but i'm sure some one will come up with a solution...
here is the info i know.
XBOX360 can't display two screens at a time using two different cable types.
HDMI Capture cards are at least 140$
I can't play and record at same time if i use a USB record card. "Correct me if i'm wrong"
Thanks guys for your help and i'm waiting your answers.
Cheers.
Results 1 to 1 of 1
Capturing XBox 360 in HD
By Hyde! in forum Capturing and VCRReplies: 6Last Post: 3rd Jun 2011, 22:28 -
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
Capturing Xbox 360 video
By lostsoul99 in forum Capturing and VCRReplies: 3Last Post: 13th May 2010, 08:33 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Capturing from xbox 360
By VirTu3 in forum Capturing and VCRReplies: 43Last Post: 21st Jan 2009, 13:11
