Hi--
My first post. I want to make Video DVD's essentially only for AC3 5.1 sound playback-- the image will not be used and I want 6-12 hour long sound pieces. I'm just getting started using ffmpegX and having assorted issues using the QT and MPlayer encoders, but I was wondering if anyone is aware of actual bit rate minimums or other factors I'm overlooking. The AC3's are 448 kbps; I'd like video rates of 50-100 kbps, if possible. Thanks
If by compliant video track you include a BMP picture (which gets converted to a single frame M2V, I believe), then yes. And the minimum bitrate can be set at zero. I make all mine with a minimum of 250.
I have no idea how to do this on a Mac, but Muxman loaded with a single 720x480/576 BMP together with the audio track will author a compliant DVD. The video portion will take up next to no space. I expect that any Mac authoring program fed a single frame M2V together with the audio can do the same.
Never overlook the obvious! Worked as you suggested and fantastically easy.
A test 10.1 MB AC3 track muxed with a 720 X 435 still image using DVDSP to produce a VTS_01_1.VOB file that 10.8 MB in size. DVD has some neat provisions, huh? Thanks a ton. You saved me hours of experimentation!
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
Best way to reencode mpeg2 to lower bitrate
By justcurious in forum Video ConversionReplies: 3Last Post: 22nd Nov 2011, 17:05 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
mpeg2 bitrate conversion
By sandiegoguy in forum MacReplies: 6Last Post: 16th Aug 2009, 03:40
