I used to have no problem dropping mkv files into this program, but then I messed with my codecs and it won't take them now. I tried to reinstall everything the way I had it before (CCCP codec pack) but when I try to open an MKV file in the program, the matroska icon flashes a few times in the toolbar then the error shows up. The FFDshow icons used to show up and it would load. It seems like it is using the wrong decoder, anyone have any idea whats going on. Thanks in advance!
by the way, one of the codec packs I recently added that may have screwed it all up is the k-lite pack. I tried to remove all traces of it, but that may have been the problem. Should never have downloaded it, because I use and edit a ton of different types of video files and the cccp pack was working flawlessly for so long.
Can I import 4PM or MKV with 2 Audio Streams into TMPGEnc Authoring W 4?
By JackyWang in forum Authoring (DVD)Replies: 2Last Post: 27th May 2011, 08:56 -
need help importing MKV files into Tmpgenc Xpress 4 under Win7 x64 please
By BilboFett in forum Video ConversionReplies: 6Last Post: 23rd Feb 2011, 01:37 -
TMPGEnc Authoring Works 4 & MKV
By Teac23 in forum Video ConversionReplies: 1Last Post: 14th Aug 2010, 14:29 -
Blu-ray backup/playback problems (mkv, m2ts, ffdshow, mkv splitter)
By Pyrophoric in forum Video ConversionReplies: 0Last Post: 3rd Mar 2010, 10:26 -
TmpgEnc + mkv (renamed to .avi) + .ass + ffdshow - DirectVobSub = Insanity
By Sumgai in forum SubtitleReplies: 3Last Post: 20th Jun 2007, 23:21
