I've been told most DVR's and recorders use 192 or 448 Kbps AC3, with a sample rate of 48KHz. Supposedly that rate is constant regardless whether you record your DVD at SP speed (2 hours) or SLP speed (6 hours). Is this true? I've been contemplating recording some of the DirecTV radio channels overnight (for later conversion to MP3), and if the audio fidelity is the same regardless of my DVD record speed, then I should go for the six hour setting. Comments?
Results 1 to 1 of 1
Audio freq response on various DVD speed settings? - HELP!
By will7370 in forum AudioReplies: 2Last Post: 12th Jul 2010, 15:05 -
frequency response graph
By siluet in forum AudioReplies: 13Last Post: 10th Feb 2010, 13:11 -
Frequency response correction
By siluet in forum AudioReplies: 6Last Post: 29th Jan 2010, 14:44 -
Request for measurements: 6MHz sweep response
By cybertheque in forum Capturing and VCRReplies: 5Last Post: 8th Oct 2008, 04:26 -
ADVC-300 audio capturing oddities (treble/bass response)
By Wile_E in forum Capturing and VCRReplies: 2Last Post: 12th Sep 2007, 06:48
