I have a big HD mpeg file (+/- 10 GB). Instead of making a DVD with menu's which lowers the quality, I would like to know if there is no way to create a menu in a media player with entries who jump to the different episodes in the menu (more the same thing as you get with the DVD menus).
Which mediaplayer should I use and evt. other software.
Thank you.
MultiAVCHD can author with HD mpeg-2. If it is compliant it won't re-encode.
Read my blog here.
I have a Canon HV30 camera, which gives me a 1440 * 1080 MPEG file as output.
I would leave that file intact and not create an other file format from it as my pc is rather old (2005), capable of playback but not that good in transcoding.
I want to define the episodes in that file (from time x to time y) and have a menu (not Blu-Ray format, can be a Windows app) where I can choose the episodes I want to see. This is a sort of subtitling with jump to that subtitle. -
Nope.
You need to use a recognisable structure such as DVD (with the subsequent reduction in quality) or AVCHD/BD. Otherwise you are a best limited to simple playlists defined in your player (and will have to at least split the files into episodes).Read my blog here.
Keepvid - how can you chose where the downloaded file is saved?
By jacknscoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 00:09 -
I want to set up a wi-fi but need to choose: ipod or netbook
By vhelp in forum ComputerReplies: 0Last Post: 24th Nov 2010, 20:19 -
Simple question about VLC resizing each episode while playing.
By Becki_Mason in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2009, 22:36 -
Planet Earth each m2ts file playing same episode
By mwsolomon in forum Blu-ray RippingReplies: 0Last Post: 18th Feb 2009, 00:16 -
Wont play main title. Stuck at episode select menu
By drashleyj in forum MacReplies: 1Last Post: 13th Mar 2008, 08:19
