I have an avi movie I want to burn in Toast 7. The movie plays fine in VLC. When I drag it to Toast 7, I select DVD-Video, and am able to star the process whereby I burn it to a DVD. But here's the bummer part. It encodes the dvd, then I get the following error message:
The drive reported an error:
Sense key = Medium Error
Sense Code = Ox02
No Seek Complete
I'm on a mac. Please help.
Results 1 to 10 of 10
Thread moved to mac forum.
Tip: next time, first save as disc image, so that you won't have to encode again if the burn stage fails for some reason.
This error is typical of the burner not 'liking' the media. What brand of discs are you using? SL/DL? +R/-R? Several users reported that the error didn't come up when using Verbatim discs (my favorite brand, too). -
Thanks for the reply. I'm using TDK DVD-R 1-x16x speed 4.7GB dvds. Maybe I ought to try Verbatim. What dya think?
Apple recommends Verbatim. When I use Verbatim I don't have issues (well, very rarely). Use "-R" for single-layer and "+R" for dual-layer (there aren't Verbatim dual-layer "-R").
I appreciate the suggestions. I went out to today about bought 10 Verbatim DVD-Rs, and have the same error now when I tried to burn. Bummer. My macbook pro is less than a month old. I've burned cds successfully from Itunes, but this is the first movie I've burned. Could there be something wrong with the DVD drive? If you have other suggestions, please help. Best, David
Use the "save as disc image" process so the encoding gets done and the entire "DVD" is saved to a ".toast" file. If that succeeds, then burn that image file back to a DVD. Burn at no more than half the max speed of the disc. If that fails, you probably have a bad drive and need to call AppleCare.
Yeah, I was going to to post up that Toast 7 ( v7.0.4 was the last version) topped out at 8x speed for
media released BEFORE 2002. Toast 8 ( up to v. 8.0.5) is better and can handle up
to 16 x media released up to now ( i use it still on my Tiger Mac).
for Tiger Macs, v.8.05 is best
for Leopard and Snow Leopard, as well as Intel based Macs, use 10.0.7
gotta love those Toast patches that enable it to handle the Medium, ie. Discs, you burn!"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Burning a few .AVI files with SVC2DVD
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 7th Sep 2008, 10:49 -
can I burn 2 AVI files to dual layer with toast
By BattyRoy in forum MacReplies: 6Last Post: 10th May 2008, 01:10 -
Burning several avi files to a DVD
By shashgo in forum Newbie / General discussionsReplies: 5Last Post: 10th Apr 2008, 10:23 -
Toast 8 - Can I join 2 avi files to make one video?
By Ivor Bigone in forum MacReplies: 5Last Post: 13th Feb 2008, 10:32 -
Burning .avi files
By pilgrim02 in forum MacReplies: 13Last Post: 31st Jul 2007, 12:52
