I just inherited an ATI TV wonder USB 2.0 tuner from a friend. I installed the driver and the ATI MMC. The device shows working properly under device manager on my WINXP home SP2 desktop. The MMC TV software allow me to scan for all available channels. But it is not displaying the picture. All I have is a see through square box for whatever channel I select. I was told by my friend that the ATI MMC software was never good and it failed on his box also from time to time. I tried vitual dub and I can see the TV channels no problem. However there is no audio at all. I was wondering if there is any other software that I can try with this Little uSB device.
The USB2 PVR with hardware encoding has wide PVR software support.
The software encoding USB TV Wonder has less support since it requires heavy CPU load.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Problem solved. Virtualdub works (both Video and Audio) after uninstalling ATI MMC toitally from PC.
VirtualDub is fine for manual recording. I thought you were looking for PVR software.
ATI TV Wonder 650 USB Dual TV Tuner
By s3r19lk1ll3r in forum Capturing and VCRReplies: 9Last Post: 4th Dec 2010, 22:52 -
need help with ati TV wonder 650 USB - no sound with virtualvcr
By deffy in forum Capturing and VCRReplies: 15Last Post: 6th Aug 2010, 03:16 -
Diamond ATI Tv Wonder 750 USB and virtualdub
By buckethead in forum Capturing and VCRReplies: 9Last Post: 31st Jul 2010, 03:34 -
Diamond ATI TV Wonder HD 750 USB
By Caple in forum Capturing and VCRReplies: 4Last Post: 16th Jul 2010, 20:39 -
ATI TV Wonder 650 usb software issues.....
By pinetop in forum Capturing and VCRReplies: 11Last Post: 14th Jul 2010, 06:50
