  1. PSCO2007
    May 2010
    Southern Ca.
    Hello all,
    I was using this recorder without problems until today. I had unhooked everything to reconnect a home theater system. Now, when I go to turn on the recorder, all I get is an error message on the unit - E1.
    I even tried to connect directly to tv (hdmi) -Same problem.
    The unit must be working because it is hooked into the tv antenna and I get reception.
    Any ideas appreciated, since Philips has no idea. Great support!!!
  2. PSCO2007
    May 2010
    Southern Ca.
    Originally Posted by Psco2007 View Post
    Hello all,
    Figured out the problem. The receiver was on the wrong input-it used to work on HDMI 1, but now it works on "BD".
    Don't know what changed, but it's good now.
