  1. I have Rossetta Stone .iso files, they are not working when I run them with MagicIso. It only opens up the File folder so I can see the contents of the .iso. Anyone know how to make this work? Do I have to get a different program? Thanks for the help!
    Feb 2008
    Twin Peaks
    What exactly is preventing you from burning it to a CD/DVD and using that?
  3. Originally Posted by lowellriggsiam View Post
    I dont have a DVD Burner on my Laptop.
    Its a big(ish) file too/ 1.4 GB.
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Yeah, you have to mount it to a virtual drive, you could try MagicDisc, Daemon Tools, DVDFab Virtual Drive, ect.
    This what the "TOOLS" section is for
    https://www.videohelp.com/tools/sections/iso-image
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Why not install from the original program disc(s), then? (Why go to the trouble of converting commercial software to ISO images if you're not going to burn them to disc?)
  6. Originally Posted by Noahtuck View Post
    I appreciate it. I can move my thread there.
  7. Originally Posted by Ai Haibara View Post
    I didn't convert them to ISO image. It was converted for me, now I dont know what to do with it.
  8. I'm a Super Moderator johns0's Avatar
    canada
    Contact Rossetta Stone about obtaining a copy of their program that you bought and have the cd/dvd sent to you,having an iso of the program is considered warez unless you have the original cd's that were sent to you.
