I need a software player that can play Blu-ray ISOs. I've tried the latest trial versions of PowerDVD 10 and TotaMedia Theater 3 but neither recognizes ISO's as a valid file format. I mounted the ISO using Virtual Clone Drive and PowerDVD will play it but TMT3 won't. Is using PD10 and VCD the only way to accomplish this?
Do you have TMT3 fully updated? I use it in combination with Virtual CloneDrive to play blu ray ISO's and have no problems.
Edit: I'm using Win7. The last update for TMT3 shows a bug fix that says Virtual CloneDrive is now supported on Windows XP.Last edited by Kerry56; 12th Jul 2010 at 20:38.
Thank you to those who have responded. Since I downloaded the trial versions this past weekend I assume they're the latest versions. I'm using 32-bit Windows 7.
From the responses thus far it sounds like neither program can open an ISO directly so I must use an ISO mounter. I mounted the ISO as drive "V:" with VCD, PowerDVD saw and played it; TMT3 did nothing when I told it to play drive V.
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 18:25 -
Set-top Blu-ray player that can play IFO
By AndyRough in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Sep 2011, 05:35 -
Need help creating a BD-R that will play on Blu-Ray players
By cmw in forum Authoring (Blu-ray)Replies: 11Last Post: 28th Jul 2011, 09:59 -
Blu ray players with fast play with audio?
By videdit in forum DVD & Blu-ray PlayersReplies: 3Last Post: 28th Dec 2009, 19:53 -
Which Software Players Can Play Blu-Ray and HD-DVD Files?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 14th Nov 2009, 00:29
