I'm goign to need more power to feed the graphics card i've just moved from one PC to another.
It Needs an 8Pin PCI-E as well as a 6Pin PCI-E.....i dont have this amount of plugs on my 850w supply.
I do however have a spare power supply. I was looking around how to use both to do what i need and found this:
http://www.ehow.com/how_5054443_use-power-supplies-one-computer.html
I've always been wary of ehow and unsure of how accurate the information is, can anyone verify that it is in fact as simple as this ??
	It is pretty much that simple, however the warnings they give aren't as inclusive as they should be. Jumping the PSU like that means it will always be on unless you shut it off using the hard switch on the PSU or pulling the plug, it doesn't use the power switch on the PC. In fact you need to be absolutely sure that you power this auxiliary PSU on before you power on your PC and power it off after you power off your PC. If you don't then you could damage your system by powering on/off devices that aren't meant to be hot-swappable on the board. FB-DIMM are the real cause of global warming
	Dear Lord, what the dickens (Notice English reference) are you running on your PC to need that much power !
 http://www.extreme.outervision.com/psucalculatorlite.jsp
 Do remember he is using 240 volts folks !PAL/NTSC problem solver.
 USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
	yeah..have you really used up 850W or do you just need an extra plug? If you just need an extra plug then you should be able to just get a Y adapter for your existing power supply.
	I agree with greymalkin, you can get an adapter to get an extra PCI-e 8 pin plug or use a molex=>PCIe 6-pin adapter
 But if you are exceeding the capacity and require 2 PSU's (and don't feel like making your own connector) , you can buy pre-built ones e.g.
 http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=34_186&p...ducts_id=21193
	I'm getting very close to power and its not just running out of plugs, although that is also a factor. The graphics card itself uses 289W of power alone!!! As i have the second PSU already then it seems like a good solution at no cost. (The card is the GTX 295 hence the heavy power drain)
 That cable you linked to Poison looks good as it would link to the main power button as well. I may consider that, at the moment i've managed a pretty good link and it seems to work fine and the voltages look right so going to install it in a bit.
 Cheers for the warnings Rallynavvie, i figured that'd be the case anyway with keeping its power on at the right times etc.
  Lacie Cinema: Can't power device on using remote but will power on with USBBy truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03
  Any of you upgrade your power supplies?By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 14Last Post: 16th Sep 2011, 23:36
  Merging/Converting Multiple M2TS files to MKV With Multiple Audio TracksBy Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34
  Building a Low Power Desktop...with Laptop like power?By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 23:15
  Power supplies - which one...????By kenmo in forum ComputerReplies: 11Last Post: 11th Jan 2008, 18:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
