Hello,
I have bunch of quicktime .mov files with closed captions within. Does anyone know how to extract its subtitle and convert it to .srt file or something?
It is obviously in text format in the .mov file, not in graphic file format. I am able to extract the text with some tools but it doesn't have timestamp info so that I can convert it to .srt.
I've got those files from here: http://openmedia.yale.edu/projects/courses/fall06/rlst145/mov/rlst145_02_091106.mov
(it is 500M-600M bytes, huge.)
I appreciate your help in advance.
Thanks,
K
If you revealed what operating system(s) you use and what tools you have tried unsuccessfully, it might be helpful to anyone trying to answer your post.
That's about all I can offer you. The programs I tried to use for extractions the captions did not work with a partial file, and downloading the entire video would take a long time with my slow DSL connection.
Extracting text from .caption file
By dan2004 in forum SubtitleReplies: 3Last Post: 17th Nov 2011, 12:41 -
looking for tool to cut commercials then rip closed caption of ts file
By hunk in forum DVB / IPTVReplies: 2Last Post: 3rd Nov 2009, 19:22 -
Closed-caption subtitles in UK
By kasfig in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2007, 12:50 -
Extracting Closed Caption and writing it back to mpeg as open caption
By CBiLL in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2007, 03:50 -
disabling Closed Caption Texts
By pskim in forum SubtitleReplies: 2Last Post: 5th Aug 2007, 11:36
