I'm finishing editing and subtitling a video on Final Cut Pro (7.2) and the client asked to finish it on AVI. He intends to put it on internet. I have MPEG Streamclip and I guess it can do it but he also asked not to exceed 100MB. I have no idea how to do the settings with MPEGS to achieve that. The video has 11 minuts and I'm using the PRORES 422 on the timeline.
Thanks you all in advance.
MPEG Streamclip should let you adjust the bitrate to what you need. Click the Limit Bitrate checkbox and type in a number (start at 1000kbps and see what size it tells you it will be). Also adjust the audio down to about 64kb or even 32kb (it's going on the Web, after all, not to a theatre). Keep checking that MB size of the file (to the right of the video bitrate you're adjusting). If available, crank up the quality slider; the encoding will be slower but you don't care.
Let us know how it goes.
Edit: If my math is working okay, a 100MB file at 11 minutes = 9.09MB/minute /60 seconds = .151mbps x 1024 = 155kbps. 155kbps is going to be awful quality unless the frame size is like a postage stamp. Others will probably check my math.Last edited by rumplestiltskin; 11th Jul 2010 at 22:21.
Question about converting 174 minute DVD movie to 700mb avi
By jimdagys in forum DVD RippingReplies: 8Last Post: 7th Mar 2009, 04:18 -
Cannot get trimmed a DV-AVI movie in MS Movie Maker
By askmaxim in forum EditingReplies: 0Last Post: 30th Dec 2008, 06:44 -
Converting a Shockwave file (non-movie) to FLV movie
By beyondthegrave in forum Video ConversionReplies: 3Last Post: 22nd Nov 2007, 01:18 -
DV-AVI widescreen 16:9 movie from Windows Movie Maker.
By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 11:37 -
Help converting home movie dvd to avi/wmv for web
By dancingbear0420 in forum Newbie / General discussionsReplies: 2Last Post: 24th Aug 2007, 14:35
