I've used this program with much success, mostly with .MKV and .MP4 files. Some .AVI files I've tried to process do not work properly. When I import the .AVI, then edit the file to add subtitles, I press the play button and there's no audio. If I double click the .AVI to open it in Windows Media Player, the audio plays just fine. Has anyone else experiencing this?
I'm having the same problem. I have 20 avi files in the project. All of them have audio except one and all were ripped from the same source (a DVD). The audio for the trouble file is listed as:
44100 Hz, 2 ch, 0 s 3
DivX file reader
All others have audio listed as:
MPEG-1 Audio Layer III, 44100 Hz, 2 ch 7 min 40 s 15, 128 kb/s -
Encode video in an encoder, not authoring software.
I used Xilisoft DVD Ripper Ultimate 6 to rip the avi files from the DVD, not the authoring software. I don't have any problems with the other avi files and I've ripped hundreds.
The problem file will play in Windows Media Player, WinAmp, and any other player, but the audio doesn't work when I try to play it in TMPGEnc Authoring Works 4 or when it's burned to a DVD.Last edited by meezark999; 12th Jul 2010 at 08:05.
Sorry, I should have listed the audio format of the latest video I tried to author. It's AC-3 with mode extension CM (complete main). I actually fixed it after some more research.
It wasn't the fault of TMPGEnc Authoring Works, I had to install FFDSHOW, then use Win7DSTweaker to change the default system decoders to use FFDSHOW. This actually fixes another problem I had, trying to import an .MKV (Matroska) file, and getting a message telling me audio was imported but not video. So a combination of FFDSHOW / Win7DSTweaker was the answer.
Thank you to those of you who replied.
Re problems editing in tmpgenc authoring works 4 using multiple video files
By ukcalibrauk8 in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2011, 02:25 -
TMPGENc Authoring Works 4 - motion menu no audio
By mobie29 in forum Authoring (Blu-ray)Replies: 3Last Post: 16th Jul 2010, 16:32 -
Invalid audio bitrate error on TMPGEnc Authoring Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 12th Jun 2010, 23:13 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
Problem loading Blu Ray files into TMPGEnc Authoring Works 4
By DSguardian in forum Blu-ray RippingReplies: 0Last Post: 14th Apr 2010, 19:52
