  1. Hi,
    I'm trying to rip "What Women Want", using DVDx 1.8 frameserving to TMPGEnc, but I noticed in the DVDx plug-in window that audio and video are out of sync, being audio frame higher than video around 9 to 12 frames... does anyone know what could be going on?
    thanks in advance,
    marcelo_magri
    Athlon XP 1600+
    ECS K7S5A
    256 Mb RAM
    Maxtor 5200rpm 40 Gb HD
    Riva TNT2 32 Mb Videoboard
    Hollywood+ MPEG card
    Toshiba 6x DVD-ROM
    LG 16x10x40 CD-RW
  2. Hi,
    If you ONLY use DVDx, the Audio in your final MPG might get out of sync with Video.
    I got the same out of sync problem too using DVDx1.8a, Video Server plug-in, TMPGenc 2.53.
    Looking at the Plug-in window during the encoding process, I noticed that the Frames of Audio was somehow faster than Farmes of Video. This was done without spliting the Audio from Video (eg Video Source = Audio Source) in TMPG.
    So I try spliting by saving the Audio in Wav file and convert it to mp2 (can be configured in the Plug-in). After I started the encoding process with TMPG, I noticed that the Frame of both audio and video got to sync.
    After I got the mpg and mp2, I used the TMPG Tools to mix into 1 mpg file.
    I have not tested with the mpg I've made but you can try if you want.
    In my opinion, TMPG is MUCH MUCH MUCH faster than DVDx.
