  1. Member kwanbis's Avatar
    May 2008
    Argentina
    I bought VOB2MPG PRO, and i'm using to rip my series DVDs to MPG.
    Now, each time i introduce a new DVD, i have to select all 8 titles and all 8 audio streams, even if there is only one stream, so, can it be made so:
    1) VOB2MPG PRO selects all titles based on a min num of secs, like, if it is more than 120 secs, or user definable, auto select the title.
    2) auto select a predefined audio stream, for example spanish, user definable, or, if only 1 audio stream, select it.
    3) if i select an audio stream, automatically check the title to be ripped.
    I do not think it would be too much work to implement, and it would be really helpful.
  2. Member kwanbis's Avatar
    May 2008
    Argentina
    Is it possible?
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    1: should be possible (you know you can Right Click->Select All Titles?)
    2: should be possible also (if there is one audio stream only then there is nothing to select as it will be the default)
    3: i would say that may lead to a bit of confusion to some users.
  4. Member kwanbis's Avatar
    May 2008
    Argentina
    1) didn't knew. Maybe a select all button. But still think the other idea is better
    2) There are some titles where there is no default audio, and i have to select it each by each.
    3) could be. 1 and 2 are more important. And if done, there is no need for 3.
  5. Member kwanbis's Avatar
    May 2008
    Argentina
    So, any update?
    And by the way, if the VOBs can contain many audio channels, why can't i choose more than 1 when "converting"?
