well, I'm new to use MEGUI + avisynth
this is the AVS script i use
video=AVISource("C:\Users\Squall0833\Desktop\01.av i")++AVISource("C:\Users\Squall0833\Desktop\02.avi ")
audio=WAVSource("C:\Users\Squall0833\Desktop\01.av i")++WAVSource("C:\Users\Squall0833\Desktop\02.avi ")
AudioDub(video,audio)
both of the avi 01 and 02 have audio, I'm going to join them together into 1, included audio, it seems the result I got is a joined avi video with no audio
my MEGUI doesn't read and encode the audio from the videos and join them, because I start the job by clicking the "Enqueue" at video section only, audio section remain empty(cos It doesnt have option to join audio files)
so, i was trying to do the audio job with avisynth, it seems it still doesn't do audio job for me , only encodes video.
I'm new to this, don't really know if there's other way to do that.
can anyone teach me?
WAVSource() is for demultiplexed PCM wav source (yours is embedded in the AVI stream) , that's why it's not "picking up" the audio
AVISource already has audio=true by default (i.e. it passes through the audio embedded in the AVI file)
vid1=AVISource("C:\Users\Squall0833\Desktop\01.avi ")
vid2=AVISource("C:\Users\Squall0833\Desktop\02.avi ")
vid1++vid2
That script specifies both audio & video. So you can use the same script for both the video encoding section, and the audio encoding section
You can preview your .avs scripts in a media player (e.g. MPCHC, or MPC) , to make sure they seem ok before encoding (if there is an error you would just waste time encoding) -
What type of audio in the AVI stream? use mediainfo . Do you have an ACM audio decoder for it?
If you type info() at the end of the script , does it report that audio is being passed through?
You could also use another source filter , like ffms2, which runs independent of system installed codecs -
lame mp3
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 15mn 34s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 14.3 MiB (14%)
Alignment : Aligned on interleaves
Interleave, duration : 922 ms (22.11 video frames)
Interleave, preload duration : 208 ms
Title : AVSEQ02
Writing library : LAME3.98r
Encoding settings : -m j -V 4 -q 2 -lowpass 17 -b 128
tried to play the avs on mpchc, it's fine, It's exactly what I wanted,
the reason should be MEGUI doesn't process audio stream for me -
If that .avs file previews in mpchc correctly, it should work
Is there a log file or error message?
What audio encoding settings did you use? Did they have matching settings (e.g. 2-ch audio, and you used a 2-ch profile?)
If you don't want to re-encode the audio (lose quality) , and just want to join them, you could use direct stream copy in vdub to append the videos, then demux the joined audio stream . I think mp3 directcut may be able to join without re-encoding too -
virtualdub doesnt support xvid?
I'll try simple way, take out the mp3 audio from both avi and join them into a single mp3 file,
then just mux it into the complete avi file
thanks for the helpLast edited by squall0833; 11th Jul 2010 at 09:34.
About using AviSynth scripts with MeGUI 0.3.5.0.
By Nagashi in forum DVD RippingReplies: 56Last Post: 15th Jul 2010, 10:15 -
How to join AVI files with multiple audio streams
By V@no in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2010, 22:17 -
Convert a DVD to an avi,mkv using Avisynth Scripts and VDubMod or MeGUI
By ppeterr in forum DVD RippingReplies: 6Last Post: 25th Apr 2010, 05:04 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
