Hello,
I've ripped several DVDs to my hard drive that I want to edit in Premiere Pro. I've been using a method of creating AVS files and importing the files into Premiere, however I have almost 86 AVS files and I keep running into memory problems.
Is there a way that I can convert the VOB (or AVS) files to DV AVI for editing in Premiere Pro?
I'd also prefer to combine the VOB & AC3 files into a single DV AVI if possible, just to keep syncing issues to a minimum.
Is there a method for this conversion that will prevent quality loss? My final format will be h.264 files that will be uploaded to YouTube. The original DVDs are just standard Widescreen 480i files.
virtualdubmod should be able to do this if you have a DV codec installed
slow editing on cs4 premiere
By maplewood in forum EditingReplies: 22Last Post: 2nd Feb 2012, 13:41 -
Samsung HMX200 Footage & Premiere Pro CS4 Problems
By gs1 in forum Newbie / General discussionsReplies: 0Last Post: 8th Nov 2010, 00:32 -
Need help on premiere pro CS4
By george2005 in forum EditingReplies: 5Last Post: 27th Mar 2010, 05:42 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 18:10 -
Adobe Premiere Pro 1.5 files comptible with CS3/CS4?
By vid83 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Feb 2009, 15:15
