This has happened with both "Daniusoft"(trial version) and "Ulead DVD MovieFactory 6 Plus" (full paid $130 for version).
Daniusoft did this every time, while Ulead worked before, now it does it.
After I click the burn button, it converts video and titles, etc. for about 1 hr, gets up around 41% or so, then when I come back to check; it's gone. Not even an error message; just disappeared.
I've no idea what's wrong. Can someone please help?
Thank You.
Results 1 to 10 of 10
Burn with ImgBurn.
When I select "Create ISO image" it doesn't create an ISO image or make DVD folders. Like I said, it just closes for no apparent reason.
Do you have enough disk space?
Does the app have any settings for "temporary files" or similar - make sure that you set this to some drive that has at least 10 GB free. Authoring apps need at least that, or maybe 15 or 20GB space, to create a 5 GB DVD.
Open "My computer" on the drive it uses and watch the amount of free space as it works. -
Yes, it has "Temporary Working Folder" which is on a HDD that has 190GB free and I delete the content before each attempt. It also says how much space is needed for the burn usually 19GB or something. Also, Ulead DVD MovieFactory 6 is installed on this same harddrive so it has no reason to run out of space. Space is not a problem.
Perhaps RAM errors? Could be worth running a memory check.
http://www.memtest.org/
DVD authoring programs - suggestions?
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 22nd Apr 2010, 13:53 -
Recommended DVD authoring programs...
By mjl1297 in forum Newbie / General discussionsReplies: 23Last Post: 18th Feb 2010, 21:14 -
DVD authoring programs and their MPEG2 encoders?
By Valnar in forum Authoring (DVD)Replies: 7Last Post: 27th Dec 2008, 09:26 -
Should I consider other programs then DVD shrink for DVD9 to 5 authoring?
By geepondy in forum Authoring (DVD)Replies: 11Last Post: 3rd Apr 2008, 17:42 -
The best Converting/Burning/Authoring programs?
By whatever911 in forum Authoring (DVD)Replies: 11Last Post: 23rd Jul 2007, 14:01
