Okay, I haven't authored a DVD for a long time. But I had two some discs that I want to arrange in order and put some nice menus on.
I ripped them with DVD Decrypter in ifo mode producing a single VOB file for each ep. Like I said, it's been quite a while.But I don't remember having any problems just dragging and dropping .VOB files in older versions of the program.
Now it wont accept .VOB files? It's a DVD authoring program! WTF? It appears my only option with this program is to rerip all the discs as isos. Is there a DVD authoring program that will accept .VOB files?
Results 1 to 10 of 10
What makes you think it will accept ISO files?
What makes you think a single VOB file is acceptable as "Add DVD Video" when true DVD Video is never one single VOB file?
If you want to "Add A File"...the VOB file might work. -
You can't drag and drop the VOB files. You'll need to navigate to the disc's VIDEO_TS folder using "Add DVD Video".
Thanks forall the replies.I have tried to just add a file.That doesn't work either. I guess my only option is to rerip the discs.
Yep, re-rip properly.
Guides for this at http://www.digitalFAQ.com/guides/video/index-edit-encode.htmWant my help? Ask here! (not via PM!)
try this.. rip with dvdfab7 then in the author program extract the mpg movie files from the video-ts folder of vobs, then use the author program to arrange the mpg files and then reauthor a new set of vobs which is created in a video-ts folder. You can now burn as a dvd. if the files are to big to fit disc then use dvdshrink to reauthor to a suitable size to fit dvd disk
I would not suggest that.
That's not what authoring programs are for, and it commonly leads to errors.
sorry have to disagree i have used tmpgenc author for many years and have not come across any errors in extracting mpg movie files from video-ts folder of vobs once extracted editing can be done on the mpg files in an editor then can be authored with dvdflick if necessary to make the file smaller to fit dvd 4.3gig disc if using dual layer then no problem. -
That's really the only authoring program that can do that, plus it's still not 100% effective. I've seen it choke on more complex commercial DVD sources.
HD containers and PS3 driving me nuts!!! = SONY stop being so lame!
By heinza in forum Video ConversionReplies: 13Last Post: 2nd Jan 2011, 21:18 -
Bugs Bunny is driving me nuts.
By G)-(OST in forum Off topicReplies: 15Last Post: 24th Jun 2009, 22:52 -
Printer driving me nuts
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 27th Dec 2008, 09:47 -
This cdex is driving me NUTS!
By Jo The Veteran in forum AudioReplies: 4Last Post: 18th Oct 2008, 09:26 -
v2.5.3600 runs very slow and driving me nuts...!!!!
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 6th Oct 2008, 10:00
