My new Sony system burns cheapo DVD-R's ok but doesn't like Princo DVD-RW's. The recorder is a Pioneer 104 which the tech as Sony thinks could be the OEM version of the A04. Should I reduce the speed to 1x? Can anyone vouch for the Princo DVD-RW's for use with the Pioneer A04 (or 104?) burner?
Thanks,
Sean
They work fine with my A03 so I would have thought they would be fine with the newer model.
Incidently, you can now get Princo branded DVD-RW blanks from
http://www.bigpockets.co.uk
for only 2.09 UK pounds per disc. Almost as cheap as DVD-R woohoo.. off to order lots
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 16:25 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 07:57 -
This Old Princo
By hech54 in forum MediaReplies: 10Last Post: 16th Oct 2009, 17:01 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 14:34 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00
