Results 31 to 60 of 490
The ASUS card you have ordered will fix this problem. The reason for the bandwidth exceeded error is because your motherboard has negotiated a PCIe Gen 1 speed for the slot your card is plugged into. The SIIG card you have is a single lane Gen 2 card but your motherboard is only letting it run at Gen 1 speeds. Gen 1 is 2.5Gb/s and Gen 2 is 5Gb/s. Hence the bandwidth error - the Shuttle needs the 5gb/s PCIe speeds.
The ASUS card is a 4 lane Gen 1 PCIe card that folds two lanes together to form two single lane Gen 2 slots - one for the USB3.0 host controller and the other for the SATA controller. This means you are *guaranteed* to get a Gen 2 connection to the USB Host Controller.
There is a possibility that your motherboard has a BIOS setting that will force your PCIe slots to be Gen 2 and so allow your SIIG card to work with the Shuttle. -
I just received my Shuttle and when connecting it to my laptop Device Manager reports "the device cannot start code 10".
I'm using a Dell M1330 laptop / 3GB / SSD and connecting with a SIIG ExpressCard/34 - http://www.siig.com/ViewProduct.aspx?pn=JU-EC0112-S1 I am using the external power adapter with the ExpressCard as well.
I'm not expecting to do 1080p with this setup of course, but right now I cannot get the system to recognize the Shuttle even to change setting with the control panel app. -
Yeah, it's not going to work. Current ExpressCard standards are equivalent to PCIe x1 gen 1.0 speed at 2.5Gb/s. That's not enough for Intensity Shuttle.
Blackmagic Design -
Thanks for the info.
Is there a site that has system requirements to handle the IS -
Hi,
See this one:
http://blackmagic-design.com/support/detail.asp?techID=201Blackmagic Design -
Yes, I did - when I purchased the Shuttle in May (then followed a trail of delays from Blackmagic). It looks like last week this was added to the site in the form of an FAQ. Since Kristian Lam is confirming from Blackmagic it doesn't work I'm going to return the Shuttle - if it will be chained to a PC then there are cheaper options for my needs.
sorry, i thought the specs came out before the product. that's how it should have been done.
Ok so the good news is that i actually got things working in Media Express with the ASUS USB3 card after failing with the SIIG.
At first i was getting blank video from my Sony Handycam via HDMI. APparently the Shuttle cant handle the 1080p put out by the Handycam, so i had to go into the handycam setts and change it to 1080i and the feed appears in the "capture" window.
That's all well and good, but now I am having more trouble. The first thing I wanted to do is use the camera stream with Flash Media Encoder. I close Media Express, start FME, and then when I choose "Decklink Video Capture" as the device it says "Problem with Video Capture Device". Also, if I try launching LiveKey, it shows "Can't Create Decklink Video Capture Filter". So basically, it does not appear I can use the Decklink Video Capture device at all with the Shuttle. Is there anything I can try to fix this? -
Update 2:
So I tried rebooting, and upon startup a message popped up that said the Shuttle's Firmware needed to be updated -- I clicked OK and it installed and said the Shuttle had been sucessfully updated and was ready to use. Unfortunately that did nothing to fix the "Decklink Video Capture" problem when I then tried launching FME.
This seems really strange, because when I launch Media Express the video stream beautifully appears in the Capture window and it definitely is working there, but it wont work in other applications when I try to specify the "Decklink Video Capture" source.
So I then tried rebooting again, and again the same firmware update notice appeared. I clicked OK, and it installed the firmware to the Shuttle just like the first time. Now I am suspicious this might happen every time I reboot, and sure enough, it does! To test I have rebooted the computer eight times, and each time when Windows starts the dialog appears to update the Shuttle firmware.
Can anyone else try this (especially anyone using the ASUS USB3 card)? -
I can get it to capture with Adobe Premiere Pro! I can't get it to work with Vegas 9 pro though. (It's a trial though i don't know if that matters or not?)
Hello guys I know that this question is probably asked a lot but i still don`t get it
I got my intensity shouttle today
followed all th instructions with the NEC 3.0 and frimware and on USB 3.0 Controll Utility everything is so as in the instrution.
When I plug in the CC my PC just don`t detect it on USB 2.0 it says intensity shouttle...
So what am I making wrong??
I Have a Asus x58 based motherboard with intigrated 3.0 usb -
Hello all first time poster so be gentle
Having some issues with my Intensity Shuttle
1. On clicking Livekey I receive this message - Can't create Decklink capture filter
2. On restarting my computer I receive a prompt to install drivers however on accepting I receive: an error has prevented video codecs from being installed. You may need to reinstall Blackmagic Decklink Error code 0x80080015
Desperate here been trying for two days now to get this to work don't know how many times now I've uninstalled reinstalled restarted but its definitely in the high 20's
All USB 3.0 drivers and firmware have been updated as directed in installation instructions 2.0.4.0 (driver) and 3.0.2.5 (firmware)
Beginning to think a power outage that occurred just after installation when the shuttle is supposed to update its firmware caused an internal fault because I am absolutely stumped.
Thanks in advance for any help offered.
P6X58D Premium motherboard
Intel i7 Core 930
Windows 7 64 bit
6G RAM
1T HDD -
I had that exact problem before with my other usb3.0 PCIe x1 2.0 card but when i installed the ASUS x4 PCIe Card it worked and installed new firmware for the shuttle. But livekey still doesn't work for me either but i'm not exactly sure what it is anyways lol. Does the shuttle work with Blackmagic Media Express?
Hi everyone,
First time poster. I am trying to use the intensity shuttle on a newly acquired ASUS N61-JV, which comes with a native USB 3.0 port.
The laptop uses Intel's HM55 chipset, a Core i5 processor, and Renesas Electronics USB 3.0 Host Controller with driver version 2.0.4.0 and fimware version 3025. I am using Windows 7 Home Premium 64-bit and the latest Intensity Shuttle drivers from the BlackMagic website.
Although Blackmagic Intensity Shuttle does appear in the device manager, the device status indicates: "This device cannot start. (Code 10)"
Also, When the laptop starts up with the Shuttle connected, I get the following error message:
USB Controller Bandwidth Exceeded
The controller does not have enough bandwidth available for the Blackmagic Intensity Shuttle, which has requested 1% of the bus bandwidth.
The items listed below are being used by a program and are consuming bandwidth.
Controller Bandwidth Used
Port1 10%
Port2 10%
It seems stange that the controller cannot allocate the 1% bandwidth requested by the Intensity Shuttle if only 10% of the bandwidth is being used.
Anyone has an idea of how to fix this problem? I understand that Blackmagic only rubber stamps the HP envy so far, but I cannot understand why it should not work on a system built with a native USB 3.0 port? Thanks for your help! -
the only built-in usb3 ports that will work are on x58 chipsets and even of those only 4 have been tested as working. other than those an add-in usb card is required for p55 chipsets and add-in cards through expresscards don't work.
The thing is my motherboard has USB 3.0 integrated and its on the confirmed list to work with the shuttle, its not a PCIe card at all. Nope I can't get a picture anywhere not in media express or sony vegas pro 9e. Think I have sent about 10 emails off the Blackmagic but still no response. I also keep receiving the prompt to install drivers whenever my computer returns from sleep mode but still get an error has prevented video codecs from being installed. You may need to reinstall Blackmagic Decklink Error code 0x80080015
the problem is that I can`t setup output how do i do this ???
The other thing is that I don`t have a picture on my monitor when i put the HDMI kabel through the intensity.........
can you add me on xbl KD I En J o Y -
Ok I finally have picture but no sound I had sound with no picture then I clicked 720p @ 59.94 which gave me picture and sound then my system restarted because of a windows update now I have no sound just picture. I hear the sound clearly through my tv but no sound is recorded on capture. What the hell is going on?
This device is very annoying. -
I get picture and audio just fine in media express and have never gotten the 0x80080015 error so Im thinking it had something to do with your power outage. I would try doing a system restore to some point before you first installed the USB 3.0 Desktop. And just to be sure, you are installing the "USB 3.0 Desktop" from the download section, not "DeckLink", correct?
So on the DeckLink note, I am wondering why after installing the USB 3.0 Desktop that a "DeckLink Video Capture" source is added to Windows instead of something like "Shuttle Video Capture"? Considering that so far noone has been able to get the "DeckLink Video Capture" source to work, it probably shouldn't be there. This is getting frustrating, I also contacted the Blackmagic support a few days ago and havent heard anything yet. Pretty much just twittling my thumbs waiting for an answer so I can proceed using the Shuttle with Flash Media Encoder... -
I have the same problem with Thinkpad w510 which uses the QM57 chipset. I am pretty sure the 1% bandwidth is not the problem (I guess this is just some wrong error message). I am pretty sure the problem is the internal connection between the USB 3.0 and the chipset which is a bottleneck (so you don't get the 4.8Gb/s. That is the same problem with Expresscard. With Expresscard you only have 250 MB/s maximum.
The funny thing is that I have seen guys using the intensity pro card in the heavy pricely Expressbox1 from MAGMA which connects via Expresscard. I am wondering why that would work? There should be the same bandwidth problem like the Shuttle has. Or is the MAGMA box using some kind of lossless compression?
I am also wondering why the Envy 15 seems to work with the Shuttle. It has a PM55 chipset. The QM57 is based on PM55, right? The only difference I could find is the QM57 offers integrated graphics. Could that be a problem?
I hope Blackmagic makes it possible to use the Shuttle with w510 and other laptops. I would buy the Envy 15 if it was better quality. It's a shame that I can't find a mobile and professional solution for HD capture on PC.Last edited by visionlabz; 18th Jul 2010 at 15:47.
Hi guys,
We did a driver update shortly after releasing Intensity Shuttle. This driver can be downloaded from here:
http://blackmagic-design.com/support/software/register.asp?download=612
Just click on the "Download Now" button if you don't want to register your details.
Remember to uninstall any existing Intensity Shuttle driver before installing the new version.
Let's make sure you're all running the latest driver so we have a baseline to start with trying to understand the issues you're encountering.Last edited by Kristian Lam; 18th Jul 2010 at 18:59.
Blackmagic Design -
Yep I only ever opened USB 3.0 Desktop its ridiculous they even have those other files on there, except for media express they have absolutely nothing to do with the shuttle. I still haven't heard back from them either. And I don't know what Kristian Lam is on about after the first time it didn't work I downloaded the same driver back, its 7.7.1.0 just like on the disk. So it works but I get no sound and the media express window will not compact now its so big I cant even see then entire program at all. I'm seriously thinking about reinstalling my windows just to get this thing to work that's how desperate I'm getting.
BM Intensity Shuttle problem
By denisdm91 in forum CapturingReplies: 0Last Post: 23rd Jan 2012, 08:08 -
Black Magic Intensity Shuttle or Intensity Pro?
By perasbro in forum CapturingReplies: 3Last Post: 12th Oct 2011, 17:56 -
Intensity Shuttle help please..
By Norwalk2006 in forum CapturingReplies: 3Last Post: 13th Sep 2011, 21:52 -
Blackmagic Intensity Shuttle - Problem capturing from Playstation 3 PS3
By tuffjam in forum CapturingReplies: 1Last Post: 23rd Nov 2010, 21:08 -
Help Me! Intensity Shuttle problem
By hardxeno in forum CapturingReplies: 9Last Post: 15th Jul 2010, 01:41
