I have done 75 plus blu ray encodes with your program with no issues until now...
Here is my issue: I start an encode (it doesn't matter if I select 2 pass or quality (CBR)) and use all of the default settings.. I select an M2ts file (have also tried MKV) with AC3 Aften audio (the audio I always use (640kbps)). The streams demux .. Everything goes great.. The program starts encoding (lets say CBR 18 setting) .. It gives me a 2 hour time that it is going to be finished encoding in.. Keep in mind that I have a i5 750 quad core.. It is fast.. but cannot encode a constant quality blu ray movie like "Avatar" (yes, I own the Blu ray as well) in 2 hours or less.. So I let Ripbot do the encoding process.. The time ends up going up to about what it should be .. around 7-8 hours to complete. After the file is completed.. It gives me a different file size each time.. Some times it is a small Kilobyte file and some times it is a small Megabyte file that obviously doesn't work.. The file size should be a few Gigabytes at least .. So obviously something has gone wrong with my ripbot264..
Things I have tried doing:
I have uninstalled all ripbot plugins, ripbot itself, windows 7, etc.. Reinstalled all to the latest versions.. and I have tried older versions as well.. When I reinstalled Windows 7 again fresh, I even deleted my hard drive completely and made a brand new partition. After all of this I'm still getting the same issue.. Remember that I have successfully encoded 75+ movies perfectly in your program and I'm just all of a sudden having problems.. I figured something was up with my computer so I tried Megui and I can successfully encode a full blu ray no problems..
I have also looked at the log file when ripbot is running and it will display a completely different time that the encode will be completed than the actual ripbot and they will always remain different .. For instance: Ripbot will state that the movie has 2 hours remaining and the log in the cmd window will state that it has 18 hours remaining and then will just shoot up in the cmd window..
PLEASE help me guys! I really want to get ripbot working again..
Thanks!!!!!
Results 1 to 1 of 1
how does Ripbot264 think ... ?
By zero7404 in forum Blu-ray RippingReplies: 42Last Post: 3rd Oct 2011, 21:23 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 11:39 -
Audio sync problem with RipBot264
By DirkGently68 in forum Video ConversionReplies: 2Last Post: 20th Nov 2010, 14:06 -
RipBot264 problem
By brad350 in forum Blu-ray RippingReplies: 1Last Post: 15th Oct 2009, 21:40 -
ripbot264 looking for ffdhow problem...HELP
By blazepsi in forum Blu-ray RippingReplies: 3Last Post: 10th Dec 2008, 11:07
