  1. As the title states when I try to record with my easycap D60 it has no sound at all. It took forever to install this on account of instructions that don't help you at all and had to search for everything myself. I'm running this on a 32bit vista os and have tried using this on ulead which came with it as well as amcap, also when i look in the device manager it says that everything is installed correctly. I asked a friend for help with this since he had the same problem but he can't figure it out he tried uploading the folder with the drivers he uses for this but I guess it wouldnt let him. So i'm seeing if anyone can help me with this problem maybe on what to do or a link to the drivers thy use maybe? Any help is appreciated.
  2. Hello
    I have installed the EasyCap device on my pc using XP..the picture signal is ok, but the sound is very bad..can anyone please tell me what i need to do?
    Have tried all the tips with settings under sound and audio in Controlpanel and the moviemaker trick..but the sound is still bad..
    hope somebody knows what to do
    camilla
  3. hech54 you are linking back to this tread?
