Hi,
Just wondering if u can fix up or improve the quality of flv files downloaded from the internet. Found some really cool and rare videos however the picture quality is very blocky. The sound is also not the best.
These are rare videos that u really can't get or find anywhere.
There was some script i used(1-2 years ago) for improving low quality flv files, but ill have to find it (not in mine PC right now).
I used it for some blocky videos with fast moving objects.. i houp ill find the script for you. -
Hi again, i have found the script, its from december 2008, so... i guess i have good memory
Its for interlaced flv video converted to avi(using virtualdub).. so if you have progresive one you should change some setings.
I hope it will do what you want.Code:loadplugin("c:\x\dgdecode.dll") loadplugin("c:\x\mvtools.dll") loadplugin("c:\x\ttempsmooth.dll") loadplugin("c:\x\nnedi.dll") #load A&V v=avisource("get_video.avi") a=wavsource("get video.wav") audiodub(v,a) #correct video to true fps assumefps(30,true) resampleaudio(48000).getchannel(1,1) #deblock/dering s=DeBlock(quant=35).Blindpp(cpu2="ooooxx") # very strong temporal denoising (stabilisation) bv2 = s.MVAnalyse(isb = true, truemotion=true, delta = 2, idx = 10, blksize=16) bv1 = s.MVAnalyse(isb = true, truemotion=true, delta = 1, idx = 10, blksize=16) fv1 = s.MVAnalyse(isb = false, truemotion=true, delta = 1, idx = 10, blksize=16) fv2 = s.MVAnalyse(isb = false, truemotion=true, delta = 2, idx = 10, blksize=16) fc2 = s.MVFlow(fv2, idx=10, thSCD1=500) fc1 = s.MVFlow(fv1, idx=10, thSCD1=500) bc1 = s.MVFlow(bv1, idx=10, thSCD1=500) bc2 = s.MVFlow(bv2, idx=10, thSCD1=500) interleave(fc2, fc1, s, bc1, bc2) ttempsmooth(maxr=2, lthresh=40, cthresh=50) selectevery(5,2) #decimate out duped frames selectevery(6,1,2,3,4,5) #upscale to double size source=nnedi(dh=true,field=0).turnleft().nnedi(dh=true,field=0).turnright().sharpen(0.5) #interpolate to 50fps for fluent motion backward_vec = source.MVAnalyse(isb = true, truemotion=true, pel=2, idx=1,blksize=8) forward_vec = source.MVAnalyse(isb = false, truemotion=true, pel=2, idx=1,blksize=8) cropped = source.crop(4,4,-4,-4) # by half of block size 8 backward_vec2 = cropped.MVAnalyse(isb = true, truemotion=true, pel=2, idx=2,blksize=8) forward_vec2 = cropped.MVAnalyse(isb = false, truemotion=true, pel=2, idx=2,blksize=8) source.MVFlowFps2(backward_vec,forward_vec,backward_vec2,forward_vec2,num=50,idx=1,idx2=2) bicubicresize(720,576) #resize to PAL converttoyuy2() assumebff() #for PAL-DV separatefields().selectevery(4,0,3).weave() #reinterlace -
How do you use this data? What will it do?
Since I started this post, came up with this crazy theory.....It has kind of worked....It is 2 crazy to writeLast edited by Deter; 9th Jul 2010 at 21:51.
It will make youre low quality FLV in to high quality HD blu-ray.
I'm joking ok?
So, you open this script vith Avsp, put the correct path to youre plugins, video and sound.. do little tweaking/changing to the script according to youre video source, and encode it.
This is an old script, so maybe some changes are needed for the updated plugins.
I'm going to sleep now, i cant explain or help you more right now.
By.
Need urgent help to improve quality of mp3 files?
By apple4red in forum RestorationReplies: 2Last Post: 10th Oct 2010, 17:45 -
Strangest problem randonly occuring with downloaded FLV files
By apak in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2010, 06:44 -
How to get a quality DVD video from a downloaded 'flv format (Real Player)
By elaway in forum Newbie / General discussionsReplies: 4Last Post: 17th Jan 2010, 20:39 -
Protect Video Files From Being Downloaded (FLV)
By foochuck in forum Video Streaming DownloadingReplies: 1Last Post: 12th Oct 2009, 15:06 -
will changing bin files to dvd improve sound quality?
By motleycool in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 05:40
