Hallo has anybody succeeded in getting Creative SB Soundblaster Live 1024 CT4760 working in Ubuntu 8.04? If so would you kindly post full instructions?
My $ lspci -v
02:0a.0 Multimedia audio controller: Creative Labs SB Live! EMU10k1 (rev 07)
Subsystem: Creative Labs CT4760 SBLive!
Flags: bus master, medium devsel, latency 32, IRQ 21
I/O ports at ac00 [size=32]
Capabilities: <access denied>
~$ aplay -L
default:CARD=CK8S
NVidia CK8S, NVidia CK8S
Default Audio Device
front:CARD=CK8S,DEV=0
Front speakers
surround40:CARD=CK8S,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=CK8S,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=CK8S,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=CK8S,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=CK8S,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=Live
SBLive! Platinum [CT4760P], ADC Capture/Standard PCM Playback
front:CARD=Live,DEV=0
Front speakers
rear:CARD=Live,DEV=0
Rear speakers
center_lfe:CARD=Live,DEV=0
Center and Subwoofer speakers
surround40:CARD=Live,DEV=0
surround41:CARD=Live,DEV=0
surround50:CARD=Live,DEV=0
surround51:CARD=Live,DEV=0
iec958:CARD=Live,DEV=0
SBLive! Platinum [CT4760P], Multichannel Capture/PT Playback
IEC958 (S/PDIF) Digital Audio Output
default:CARD=SAA7134
SAA7134, SAA7134 PCM
:~$ uname -r
2.6.24-28-generic -
is the built-in nvidia motherboard audio device disabled in bios? appears not if ubuntu can find it, and only one audio device should be active.
Ogilvy
have you tried the latest version(maybe) of Ubuntu (Lucid 10.04) it has a better driver base.I had similar problem with a vga card.I was offered loads of different scripts and different configurations.Turn out all I had to do was go to system/administration/hardware drivers and select "switch on" for the right piece of hardware.
If that doesn't work go to the official Ubuntu forums and then go to the hardware section.You might find some help there.
I had problems with my sound blaster card with Ubuntu 8.04lts.But when I wiped the hardrive and put Ubuntu (a later version) on ive had hardly any problems.
Plus development of 8.04 is getting a little thin nowadays.I think there going to pull the plug in 2012/14.
WDTV Live to Soundblaster Audigy 2?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 3Last Post: 11th Dec 2010, 23:25 -
How to broadcast a live satellite TV by Adobe Flash Media Live Encoder
By mrweb in forum Video Streaming DownloadingReplies: 0Last Post: 19th Aug 2010, 20:08 -
Audigy Soundblaster SE Installation Problems!!!
By lapetite_66 in forum AudioReplies: 1Last Post: 2nd May 2009, 21:45 -
Ubuntu 7.10 released
By Baldrick in forum ComputerReplies: 10Last Post: 26th Oct 2007, 10:41 -
Dual Boot Ubuntu Err 21 on PC with XPPro on RAID0 Drive and Ubuntu on eSATA
By videocheez in forum LinuxReplies: 32Last Post: 11th Jun 2007, 00:51
