Hi,
What is The easiest and faster way to add a watermark (Text in the footer ) on my (mp4, FLV) videos, what applications should I use ?
THANKS
Results 1 to 10 of 10
The fastest way is to not do it. It annoys viewers and reduces the quality of your files.
If you must then you must re-encode you files. Fast then becomes a function of your computer speed (raw CPU grunt) and the codec settings. There is a Logo filter for virtualdub, which might be the simplest option.
What format do you want your video to be output in ?Read my blog here.
I don't care about the format in output since i upload my video in facebook, i want to add the watermark without any compression to not reduse quality
You need to re-encode your source and add a jpg or bmp file as a logo.
Both Virtualdub and Avidemux can do this. Avidemux has the filter built in and also can re-encode your source to a new file with the logo. -
thanks, but, i found quicktime pro 7 that make the watermarking easier of my mp4 video (without re-encoding) , i have done it with succes
that's a description http://www.geniusdv.com/weblog/archives/including_watermarks_on_videos_with_quicktime_pro_7.php
How to add a watermark to a movie.
By aligonso in forum Newbie / General discussionsReplies: 13Last Post: 31st Mar 2012, 04:28 -
How to add watermark? Please help
By lana in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2010, 04:18 -
Add Watermark To Video?
By johngomez0468 in forum SubtitleReplies: 5Last Post: 29th Jan 2008, 16:48 -
How to add watermark to a video with mencoder or how to scale with FFmpeg?
By ApplePro in forum Video ConversionReplies: 16Last Post: 21st Nov 2007, 09:12 -
How to Add a Watermark to the whole video file?
By mbextreme in forum Authoring (DVD)Replies: 12Last Post: 14th Oct 2007, 15:21
