I've connected my JVC HR-S3800U VHS recorder to the front panel of my Toshiba DR570KU DVD recorder using a composite cable for video and audio thru a SIMA CT-200 to the Toshiba. I get audio just fine but the screen is solid blue (no video). How I correct the problem?
Thanks all
PS this is my first post
Look at the menu of the dvd recorder it might have an option to select s-video or rca/composite, mine does and has regular sent me heading for the valium, or the vcr might have that option choice in the out menu.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Yep, look for a setting to change input source.
I unplugged and replugged the SIMA box between the VCR and the DVD recorder. Eureka!! It worked.
JVC D-VHS HD Recorder Question
By nlec in forum DVB / IPTVReplies: 0Last Post: 17th Oct 2008, 19:03 -
JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD Decks
By Anonymous4 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 15:23 -
Got new dvd recorder, Toshiba vs Magnavox
By heman28 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Mar 2008, 09:24 -
Recommend a good VHS to DVD Recorder? JVC?
By aim15011 in forum DVD & Blu-ray RecordersReplies: 33Last Post: 11th Jan 2008, 14:48 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
