Hi there everybody. I have a problem which is: I have an MKV file which has the audio out of sync by one second or two. The audio comes before lip movement, so, I need to put it ahead a couple of seconds. I demuxed the file and I have an AC3 audio file plus an h264 (MPEG-4) video file. Is it possible to resync the audio then mux everything back together again? Which program should I use to do this? I am sorry if the questions have been answered somewhere. As far as I read the posts didn´t see anything like it. Thanx a million guys.![]()
Thank you mates. Alan, as a matter of fact what I need is to advance the audio a bit, not delay it. As I had said, audio happens before voice, so I have to make it ahead. I tried AC3 Delay Cut 1.2.1.2 - that´s what I´ve found on the net in a haste! Didn´t work, or I didn´t heve enough patience to know how that worked. johns, how do I do that "at the same time"? Anyway, what I think I really have is a video file with an fps problem. Video stammers now and then. I don´t think it´s hardware 'cos others are OK. Vid fps is 29.97 - don´t think is blu-ray rip. Looks more like HDTV rip. Bad encoding
Thank you again guys. Sorry for the noob stuff! -
Delaycut can do that too (thus the "cut" part of the name).
It works very efficiently.
Select "Cut" and then the start position, in milliseconds. e.g., to advance 1 second, use 1000.
The end is the length of the track, also in milliseconds. Working that out is the only difficult part.
It will tell you the original length in minutes and seconds ... the gui isn't perfectly integrated with the command line.
Then "process" and it will create the new AC3 file.Last edited by AlanHK; 9th Jul 2010 at 06:57.
Thanx again. I need to look deep into that. Haven´t figured things out! You mean, I have to enter the beginning of the whole track, where I want it - like 2secs ahead: 2000ms - and then the very end of the whole track? I have to calculate that? I´ll give it a try. Thank you for the patience.
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
Strange AC3 mkv sync issues
By MarkyMarky in forum AudioReplies: 6Last Post: 6th Jan 2011, 08:40 -
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 04:18 -
AC3 Audio Out Of Sync In MKV
By XiATH in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 11:09
