Quote from TMPGENC :
TMPGEnc can not read AVI file with DV format.
The file is probably Type-1 DV format. The format is not supported by TMPGenc. Type-1format has different structure from AVI format. TMPGenc can not read the format since TMPGenc does not support DirectShow.
To solve this matter, try to save the captured or edited file as Type-2 DV format, however, there are still chance not to be able to read the file if you are using general IEEE1394 board without codec for VFW.
I am currently captrure to type-1 ( I think ) and converting with TMPGenc 12a to SVCD. But results are not the greatest.
I read the above from TMPGENC.net and want to know What is Type-2 DV and VFW codec ?
I know VFW standards for Video For Windows .. and when I capture DV, I think it usually is in type 2 format
I guess you could open your AVI in VirtualDub and save to another format if it causes problems -
Type-1 DV avi is video and audio multiplexed (interweaved) at frame base and type-2 audio and video are separated (but time multiplexed).
The latest Tempgenc can handle both.I'm always capturing with type-1:
smaleer files and ULEAD MS 6.0 can handle type-2 only up to 2GB (9min).
VirtualDub can't handle type-1 avi properly, it drops the audio track.
VirtualDub being stupid (VFW codec...)
By Katsu-kohai in forum Video ConversionReplies: 20Last Post: 13th Jun 2017, 12:53 -
ffdshow VFW codec doesn't show as an option
By dreagonea in forum Video ConversionReplies: 4Last Post: 12th Apr 2010, 21:55 -
video file won't play. need to know what type it is - what codec?
By chriscaton in forum Video ConversionReplies: 7Last Post: 12th Jan 2010, 08:20 -
How to install VFW codec alone for VitualDub?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2008, 16:44 -
Codec type mismatch for converting MP4 to FLV
By swashbuckler75 in forum ffmpegX general discussionReplies: 2Last Post: 24th Apr 2008, 12:28
