Results 1 to 10 of 10
  1. Hi there,
    I'm trying to write a .avi file to DVD with AVStoDVD, but each of the 3 times that i tried to write it, i get the same dos window, after HCenc window is closed.
    I now observed that there is a message on the bottom that says "Checking frame: ***** " and the number goes upwards. Should i leave it until it's finished with all the frames?? (!)
  2. Hi IllusionOfLife,
    After AC3 audio track demuxing step, AVStoDVD launches AC3Fix.exe which is a little app that fixes errors found in badly encoded AC3 tracks. In your case (where did you get that avi?) the AC3 track has a lot of errors. Let AC3Fix ends its work and then play the resulting DVD. If it sounds ok, AC3Fix is successful, otherwise your avi was too much compromised when it was (badly) created.
    Bye
    MrC
    AVStoDVD Homepage
  3. The avi is a movie.
    It seems endless, but anyway i'll give it one more time a go, and see what has happened tomorrow morning.
    Thanks anyway
  4. I left it all night, it finished, but the result is without sound again
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Try fixing the audio in the AVI.
    One way:
    open in Avidemux. If it wants to index the file, let it.
    Leave "video" as "copy"; "audio" choose a format like MP3 CBR at a high bit rate, say 256 kb.
    Then file/save to a new AVI file.
    Play it back to see if it's in sync.
  6. Originally Posted by IllusionOfLife View Post
    The avi is a movie.
    Of course it is... I hope
    My question about the origin of your avi has the purpose to try to understand where it comes, how it was created and why it has errors.
    AVStoDVD log file can help as well.
    Bye
    MrC
    AVStoDVD Homepage
  7. I don't know how it was created, i just downloaded it
    Here's the log file:
    <9/7/2010 1:06:03 πμ>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: PAL
    DVD Titles number: 1
    DVD Size: 4435/4435 MB (100%)
    DVD Output Setup: DVD Folder
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Users\Dionysis\Videos
    Save Log file: Yes
    Delete Temp Process Files: Yes
    Delete Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    TITLE 1 SOURCE FILES
    Video: C:\Users\Dionysis\Desktop\TheBig.avi
    Info: XviD - 498 kbps - 592x320 - DAR 1,85 - 23,976 fps - Progressive - 1:57:21 hours - 168838 frames
    Audio: C:\Users\Dionysis\Desktop\TheBig.avi
    Info: AC3 - 448 kbps - CBR - 48000Hz - 6ch - 1:57:21 hours
    Subs: C:\Users\Dionysis\Desktop\TheBig.srt
    [MediaInfoLib - v0.7.19]
    AVISYNTH SCRIPT
    LoadPlugin("C:\Program Files\AVStoDVD\Lib\VSFilter.dll")
    Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("C:\Users\Dionysis\Desktop\TheBig.avi", CacheFolder = "C:\Users\Dionysis\AppData\Local\Temp")
    Video = Video.ConvertToYV12
    #Using DGPulldown to upsize FPS
    Video = Video.AddBorders(0,6,0,6)
    Video = Video.Lanczos4Resize(720,576)
    Video = Video.TextSub("C:\Users\Dionysis\Desktop\TheBig.srt")
    Return Video
    <9/7/2010 1:14:41 πμ>
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: HCenc OPV 1-pass
    Target Video FileSize: 3949,7 MB
    HCenc Parameters: -ini "C:\Users\Dionysis\AppData\Local\Temp\DVD_1_TheBig.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Dionysis\AppData\Local\Temp\DVD_1_TheBig.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Dionysis\Videos\DVD_1_TheBig.m2v
    *LOGFILE C:\Users\Dionysis\AppData\Local\Temp\DVD_1_TheBig.HCenc.log
    *MAXBITRATE 9000
    *CQ_MAXBITRATE 2.48
    *BITRATE 4705
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *BIAS 50
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 0
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <9/7/2010 2:12:56 πμ>
    END VIDEO ENCODING OPERATIONS
    A2DVideoSource: DirectShowSource
    Created File: C:\Users\Dionysis\Videos\DVD_1_TheBig.m2v (4737,3 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 5743 kbps - 720x576 - DAR 1,778 - 23,976 fps - Progressive - 1:57:14 hours - 168669 frames
    START TRANSCODING OPERATIONS
    ReJig Parameters: -size 3949 -o "C:\Users\Dionysis\Videos\DVD_1_TheBig.ReJig.m2v" -i "C:\Users\Dionysis\Videos\DVD_1_TheBig.m2v" -auto -close -quiet
    <9/7/2010 2:16:22 πμ>
    END TRANSCODING OPERATIONS
    Transcoding executed on File: C:\Users\Dionysis\Videos\DVD_1_TheBig.m2v (3948,8 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 4786 kbps - 720x576 - DAR 1,778 - 23,976 fps - Progressive - 1:57:14 hours - 168669 frames
    <9/7/2010 2:21:09 πμ>
    END PULLDOWN OPERATIONS
    DGPulldown executed on File: C:\Users\Dionysis\Videos\DVD_1_TheBig.m2v (3948,8 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 4781 kbps - 720x576 - DAR 1,778 - 24 fps - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 1:57:21 hours - 169006 frames
    <9/7/2010 2:21:10 πμ>
    START AUDIO DEMUXING OPERATIONS
    FFmpeg Parameters: -i "C:\Users\Dionysis\Desktop\TheBig.avi" -acodec copy "C:\Users\Dionysis\Videos\DVD_1_TheBig.ToFix.ac3"
    <9/7/2010 3:43:30 πμ>
    END AUDIO ENCODING OPERATIONS
    Created File: C:\Users\Dionysis\Videos\DVD_1_TheBig.ac3 (376,1 MB)
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "C:\Users\Dionysis\AppData\Local\Temp\DVD_1_BatchMux.ini"
    BatchMux ini file:
    -d "C:\Users\Dionysis\Videos\DVD_1\VIDEO_TS"
    -mxp "C:\Users\Dionysis\AppData\Local\Temp\DVD_1_MuxMan.mxp"
    -l "C:\Users\Dionysis\AppData\Local\Temp\DVD_1_MuxMan.log"
    -muxman "C:\Program Files\AVStoDVD\MuxMan"
    -prio LOW
    -v "C:\Users\Dionysis\Videos\DVD_1_TheBig.m2v"
    -vidmode LB
    -a1 "C:\Users\Dionysis\Videos\DVD_1_TheBig.ac3"
    -a1lang en
    -cellfr "C:\Users\Dionysis\AppData\Local\Temp\DVD_1_TheBig_MuxMan.txt"
    -progfr "C:\Users\Dionysis\AppData\Local\Temp\DVD_1_TheBig_MuxMan.txt"
    -chapfr "C:\Users\Dionysis\AppData\Local\Temp\DVD_1_TheBig_MuxMan.txt"
    <9/7/2010 3:48:50 πμ>
    END DVD AUTHORING OPERATIONS
    Created Folder: C:\Users\Dionysis\Videos\DVD_1 (4417,1 MB)
    Log file created by AVStoDVD Release 2.2.1
  8. AVStoDVD Release 2.2.1
    My friend, please upgrade to latest one (2.3.1)!!!
    Bye
    MrC
    AVStoDVD Homepage
  9. Upgraded, and now even though i get the same dos window, i have audio in the output file, but no subs And i remember that I selected the subs .srt file...
    Here's the log:
    <9/7/2010 5:46:08 μμ>
    START PROCESS
    PROJECT SETTINGS
    DVD Size: 4450/4450 MB (100%)
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Users\Dionysis\Documents
    PREFERENCES
    AVS Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 6500
    Video Profile Level 2: 4500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    DVD Audio Language: EN - English
    DVD Subs Language: EN - English
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: E:\
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Save Log file: 1
    Unload ActiveMovie library: 0
    Adjust ffdshow mixer: 1
    Info: XviD - 498 kbps - 592x320 - DAR 1,85 - 23,976 fps (CFR) - Progressive - 1:57:21 hours - 168838 frames
    Audio 1: C:\Users\Dionysis\Desktop\TheBig.avi
    Info: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 1:57:21 hours - Internal
    [MediaInfoLib - v0.7.32]
    AVISYNTH SCRIPT
    # Audio is frameserved by AviSynth just for Preview and Edit purposes.
    Audio = A2DAudioSource("C:\Users\Dionysis\Desktop\TheBig.avi", CacheFolder = "C:\Users\Dionysis\AppData\Local\Temp")
    #Using DGPulldown/HCenc to upsize FPS
    AudioDub(Video, Audio)
    Encoding Profile: HCenc VBR 1-pass
    Target Video FileSize: 3964 MB
    HCenc Parameters: -ini "C:\Users\Dionysis\AppData\Local\Temp\DVD_0_TheBig.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Dionysis\AppData\Local\Temp\DVD_0_TheBig_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Dionysis\Documents\DVD_0_TheBig.m2v
    *LOGFILE C:\Users\Dionysis\AppData\Local\Temp\DVD_0_TheBig.HCenc.log
    *MAXBITRATE 9000
    *1PASS
    *BITRATE 4722
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 50
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <9/7/2010 6:59:39 μμ>
    Created File: C:\Users\Dionysis\Documents\DVD_0_TheBig.m2v (3969,1 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 4765 kbps - 720x576 - DAR 1,778 - 23,976 fps (CFR) - Progressive (TFF) - 1:57:14 hours - 168669 frames
    START PULLDOWN OPERATIONS
    DGPulldown Parameters: "C:\Users\Dionysis\Documents\DVD_0_TheBig.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <9/7/2010 7:06:02 μμ>
    DGPulldown executed on File: C:\Users\Dionysis\Documents\DVD_0_TheBig.m2v (3969,1 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 4760 kbps - 720x576 - DAR 1,778 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 1:57:21 hours - 169006 frames
    START AUDIO DEMUXING OPERATIONS (Track 1)
    FFmpeg Parameters: -i "C:\Users\Dionysis\Desktop\TheBig.avi" -acodec copy "C:\Users\Dionysis\Documents\DVD_0_TheBig_1.ToFix.ac3"
    <9/7/2010 8:36:01 μμ>
    Problems encountered during Title 1 AUDIO encoding operations.
    START (BACKUP) AUDIO ENCODING OPERATIONS (Track 1)
    FFmpeg Parameters: -i "C:\Users\Dionysis\Desktop\TheBig.avi" -map 0:1 -y -vn -ac 6 -ar 48000 -ab 448k "C:\Users\Dionysis\Documents\DVD_0_TheBig_1.ac3"
    <9/7/2010 8:41:36 μμ>
    END AUDIO ENCODING OPERATIONS (Track 1)
    Created File: C:\Users\Dionysis\Documents\DVD_0_TheBig_1.ac3 (376,1 MB)
    OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 1:57:21 hours
    BatchMux Parameters: -arglist "C:\Users\Dionysis\AppData\Local\Temp\DVD_0_BatchMux.ini"
    BatchMux ini file:
    -d "C:\Users\Dionysis\Documents\DVD_0\VIDEO_TS"
    -mxp "C:\Users\Dionysis\AppData\Local\Temp\DVD_0_MuxMan.mxp"
    -l "C:\Users\Dionysis\AppData\Local\Temp\DVD_0_MuxMan.log"
    -prio LOW
    -v "C:\Users\Dionysis\Documents\DVD_0_TheBig.m2v"
    -vidmode LB
    -a1 "C:\Users\Dionysis\Documents\DVD_0_TheBig_1.ac3"
    -a1lang en
    -cellfr "C:\Users\Dionysis\AppData\Local\Temp\DVD_0_TheBig_MuxMan.txt"
    -progfr "C:\Users\Dionysis\AppData\Local\Temp\DVD_0_TheBig_MuxMan.txt"
    -chapfr "C:\Users\Dionysis\AppData\Local\Temp\DVD_0_TheBig_MuxMan.txt"
    <9/7/2010 8:47:44 μμ>
    CHECK DVD SIZE
    DVD Folder (actual) Size: 4437,7 MB
    vs Estimated Size: 4450 MB -> 0,3% undersize
    vs Assets Size: 4345,2 MB -> OK
    Created Folder: C:\Users\Dionysis\Documents\DVD_0 (4437,7 MB)
    Log file created by AVStoDVD Release 2.3.0
  10. Could you send me the srt file? avstodvd@gmail.com
    Bye
    MrC
    AVStoDVD Homepage
