Hello,
I have MP4 (m4v) which was ripped from DVD. It looks like this in ffmpeg:
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Tribalista.m4v':
Duration: 00:52:37.64, start: 0.000000, bitrate: 1121 kb/s
Stream #0.0(und): Video: mpeg4, yuv420p, 720x352 [PAR 157:180 DAR 157:88], 29.97 tbr, 90k tbn, 30k tbc
Stream #0.1(por): Audio: aac, 48000 Hz, stereo, s16
Stream #0.2(por): Audio: ac3, 48000 Hz, stereo, s16
Stream #0.3(por): Subtitle: mp4s / 0x7334706D
Stream #0.4(eng): Subtitle: mp4s / 0x7334706D
Stream #0.5(und): Subtitle: text / 0x74786574
Does anybody have an idea how to convert it to same MPEG4 with just one sound track and burned ENG subtitles? I've been trying everything, but I can't even demux the subtitles out of MP4( Playing works normally, but I would like to just rip a piece of it with subtitles.
thanks!
Kuba
I'm running under linux, but will try it on my friend's Windows....
so YAMB reports:
Track # 5 Info - TrackID 5 - TimeScale 90000 - Duration 00:50:21.074
Media Info: Language "English" - Type "subp" - Sub Type "mp4s" - 1184 samples
Handler name:
MPEG-4 Config
Unknown (0x38) Stream - ObjectTypeIndication 0xe0
Decoding Buffer size 5028 - Average bitrate 4 kbps - Max Bitrate 3669909 kbps
No stream dependencies for decoding
StreamPriority 0
Computed info from media:
Total size 1573398 bytes - Total samples duration 3019074 ms
Average rate 4 kbps - Max Rate 55 kbps
when trying to extract either to SRT or TTXT, extraction fails with:
Track ID 5 is not a 3GPP text trackLast edited by merunka; 9th Jul 2010 at 02:55. Reason: more information added
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
Any way to rip/demux .ts h264 subtitles?
By rocka in forum DVB / IPTVReplies: 5Last Post: 2nd Jun 2010, 16:08 -
add subtitles using AVI Demux problem
By pensioner in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2010, 03:12 -
demux m2ts streams and remux them together with srt subtitles
By TwilightMatt in forum Video ConversionReplies: 5Last Post: 9th Dec 2009, 12:10 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 31st Oct 2007, 00:47
It's apparently
